Chevy dana 44
broncnaz
I think the only real differance is the spindles take a larger inner bearing. So they cant be used for the swap unless you machine them down to the earlier size. otherwise a D44 is a D44 most parts will swap although the inner shafts or at least the long side will need to be cut down and respline to be able to use it.
StJamesAuto
The dana 44 has flat sides on the front cover like where the axle tubes come out of housing and also have 30 spline inner axles. The 10 bolt gm has a more rounded or egg shaped cover with 28 spline inner axles.
roundhouse
Chevy D-44
75junebug
NW Houston Tx
Chevy used the dana 44 on 1/2 tons and 3/4 tons in the 70's. 6 lug on 1/2 tons, 8 lug on 3/4 tons. Maybe an easy way to upgrade a FW dana 44 axle ford to 8 lug??
