Ok first off i am new here and i tried to post this question in the off topic forum because i do not own a Bronco and this question is not for a Bronco. I have always liked the classic broncos for what it's worth though. And Pa Pitt said it's ok for me to ask this question in here.
For starters this is a 1994 YJ i swapped a Dana 44 front axle into using Chevy knuckles. I wanted 5 on 5.5 bolt pattern so i ended up doing the Ford 5 lug hub conversion using Chevy disc brakes.
Now that the axle is all together everything went together smoothly up until i tried to put the Warn premium locking hubs on. There is no in and out play at all and the Warn instructions say that if there is no play something is wrong. The wheel bearing retaining nuts and lock washer are on correctly though.
The axle shaft retaining clips went on as well as the outer ring retaining ring. But when i go to install the Chrome locking cap it will not fully seat. I thought it was the rubber O-ring being stubborn so i removed it and i realized that it's not a problem with the O-ring there is just no more room for the lip of the cap to fully seat once it contacts the body of the hub.
I verified that the axle shaft and the spindle and wheel bearing nuts were not contacting the body of the hub with gear marking compound. I put some on areas of the Warn hub body and bottomed it out and there was no transfer of gear compound. What is happening is the shoulder above the splines on the hub body are bottoming out on the 5 lug ford hub.
I know this mod is popular with Bronco owners when converting to Chevy disc brakes and I'm just trying to figure out how to get the jeep going again. Thanks for any help or advice you have.
