Chevy Disc Calipers ? ?
StnePny
Santa Monica, Ca.
Is there any difference in a Chevy 1/2 ton 2WD Disc Caliper vs. a Chevy 1/2 ton 4x4 Caliper ? ? ?
On the Chevy Disc Brake Conversion do you have to use the Chevy 4x4 Caliper or will the 2WD Caliper fit/work ? ?
Thanks,
Charles
I don't know if it is 2WD v 4WD or maybe something with a car application. But I have seen some calipers that are the correct style ('69-77 mid size car) but there the line bolts in won't work with 4WD.
Sorry, not an expert in GM stuff.
S
StnePny
Santa Monica, Ca.
That's what I was noticing about the one I got when I swapped mine out today. That there is a collar around the banjo bolt hole and it looks like it may have to take a custom brake line ? ? and the cating housing looks a little bigger in the rear ...
