Hey Josh and BlueB, sorry to hear about your problems! Blue, was that one of ours too? Or did you source it somewhere else? If one of ours, let me know.
Either way, I've just sent an e-mail reminder to me and will start checking what's on our shelves tomorrow.
In the meantime, we'll take return and replace, if desired, any defective unit with a good one. But let's check all the things out for sure.
I (or someone else) will check the ones at our end, but definitely do the tests described by the others to see just what's going on.
Josh, do you have any other add-on stuff hooked to that fuse by any chance?
Where did you connect the ground? I can't remember for sure, but I think the original just grounded through the case to the dash, and did not have a separate grounding wire. The separate wire is a much better, more consistent, way to do it. But still curious where you ran yours, if you did.
And when you replaced the last fuse, did you use the same size that had been blowing previously? Or did you uprate it to a higher capacity? If so, how high did you have to go before it stopped blowing?
Thanks. And again, sorry for the headaches.
Blue, since yours just failed after using it, that's an easy thing to send you out a new one. Just let me know if it's one of ours and I'll get a new one going. Josh, same thing if it turns out to be defective. We don't want to rule anything out though, so definitely do the other stuff.
Talk to you soon.
