Clearance for Dropping 302 oil pan ?
GOPSU
State College
Can I drop stock original 302 oil pan with motor in Bronco? Did some quick measurements and can't be sure pan will clear oil pickup, axle, etc. It's real close and I don't want to get it 3/4th the way out and be stuck.. I consulted Maxwell Smart and he claims it "missed it by this much."
phred
Earth
Yes it can be done. It is tight and you may have to jack the truck up at the bumper to gain a few more inches the actually get the pan to clear the oil pump pick up tube. I’ve done it before in a driveway at night to change a seizes oil pump. Took me about 2.5 hours and a 15 cuss words
Doyle
Depending on your suspension you may need to take one end of shocks loose to get enough droop.
Cooper
Northeast
To replace the pan gasket awhile back, I cut a piece of scrap 2x4 to length and placed one end on a floor jack and the other under the crank pulley and raised the front of the engine a couple inches. I also loosened the motor mounts but was careful to not raise the engine past the attaching bolts. The pan slipped out, just had to be patient getting around the oil pump (I unbolted it, let it drop in the pan and later put it inside the pan before bolting the pump back, working from one side and then the other), and was later able to lower the engine back in place without it shifting.
Alternately you could use an engine crane, I just didn't have one handy.
Anyway...hope that helps. And stay warm out there in PA !
Nothing Special
I've done it several times. It's possible, but it's a nightmare trying to get it back in without messing up the gasket, especially if you are using sealant. Still easier than yanking the engine, but it's no picnic.
broncodriver99
Glen Allen, VA
It can be done but is kinda a puzzle to get it out and back in. The last one I did was on a Bronco with 2.5" of lift, not too bad. If stock height you will need to jack up the frame to get enough clearance. Also, do yourself a favor and get the felpro one piece gasket. It comes with little plastic pins that hold the gasket to the block while you wrestle the pan and act as alignment pins. Makes the job much easier.
blubuckaroo
Grease Monkey
Ridgefield WA
I have to disconnect the track arm and jack up the car to remove the pan. That's really not a lot of preparation in comparison to other cars.
Cooper
Northeast
Oooops.
Regarding my last post, I should have said to open the hood first - especially if you have a stock hood, so the air filter or upper plenum doesn't make a dent. %)
DJs74
As said, it can be done provided you can drop the front axle and suspension down far enough to clear the pickup, unless you already have the room as it is.
Once you establish that and do the job, I suggest you pick up at least 4 threaded studs (1/4-20 thread I believe, but verify this) from your local hardware store and thread 2 into the block in each side rail... spread them out by a several bolt holes on each side - kind of shoot for as close to the four corners as possible on the side rails.
I have done this on several pan gasket changes on small blocks and big blocks and it helps tremendously.
Once you have the threaded studs and gasket in place, the studs will align the pan perfectly and allows you to push it straight up into place - then, while holding the pan in place with one hand, you can install the nuts onto a couple of the studs on both sides and the pan is fixed in place while you thread the remaining bolts.
At the end, you can remove the studs and replace them with the regular bolts or just leave them in... your choice.
I used threaded studs that had the recessed hex... AKA allen heads so I could tighten them and just left them in place. I also use them for valve covers once in a while.
DJs74
