Clicking to vibration-Transfer case? Help!
xfactor
Houston
Just bought a second Bronco ('73) on Tuesday $12000, nice frame-off someone did a few years back. New 302, C4, new paint, 3.5" duff ultimate lift, etc., everything rebuilt in 2001. The kid I bought if from (he bought it from the guy who did the resto for $16,000) had no business owing it, no maintenance, no up-keep. It's stranded at a friends house (went to show it off) 20 miles away. The idle is way too high and when I put it into reverse on an inclined driveway it clanked really hard, something broke. It clicks and starts like a rubbing clanking thing all the way up to vibration at about 20mph. I removed the front drive shaft, still did it, re-installed the front and removed the rear, locked the front hubs, still did it. Is it the transfer case? Low on fluid? The ATF level is good and I have 1st, 2nd and 3rd. When I got the rear shaft out, the rear u-joint caps fell off and the roller bearings were shavings and rust dust.It has a Duff trans case shift lever with no button. Any ideas? I need to get it home and go over it front to back for a month before I drive it again.
U
Unregistereds
Guest
first replace the 2 ujoints & the CV joint then go from there, the clank you herd may have been you leaf springs wraping up
broncnaz
Highly doubtful its the t case like posted replace ujoints and check your flex plate and torque converter could be loose also check the condition of your harmonic balancer.
Since you have driven it with either the front or the rear driveshaft removed, and the noise is still there, then it isn't the driveshaft.
Have you does it make the noise when stopped and just running?
Stopped and in gear?
Put the transfer in nuetral, transmission in gear and listen for the noise. Note: turn off the engine before shifting into park after trying this!
Finally can you safley coast down a hill with the engine off?
Not all of the tests are needed to find out what is going on, but I am trying to narrow down your problem area.
airman
I am too embarassed to say why I know this but check to see if the output yoke of the transfer case to the rear is hitting the bottom of the tub. If it is, you can tighten the t-case cross bar bolt on the passenger side or flip over the (very likely new when all the work was done) t-case bushings. You may even want to check the motor mounts.
By the way Tim, I like how you get right to it in troubleshooting. I wish I could make it this weekend but its my company christmas party and I lost my C4 when I reinstalled the t-case. I must have done something wrong. I'll have it all back by next weekend.
Jeff in AZ
You lost it? Those things are kinda big and heavy. Where was the last place you left it? You will always find it in the last place you look, unless for some strange reason you keep looking after you find it.
Seriously, what went wrong with the transmission? Just doesn’t go into gear and buzzes real bad if you shift into park while it is running? If so, then pull the transfer case and turn around the input gear.
As far as the original, unhijacked thread, I am waiting for results from the testing before I can answer any more. Since I won’t touch a computer over the weekend, I’ll see what happened on Monday.
