Hi Folks,
I just received a set of headers from Clifford Performance today. These are the ones they make for the Bronco. I'd been waiting to reinstall the engine until I had the headers test-fit to so things would be easier to work on. I was quite excited.
I test fit them and immediately found that I had to remove the dipstick because the headers are made to go through the same space that the dipstick occupies. Next, I found that with the headers bolted on, I could not install the starter. After I installed the starter, I find that the headers make contact with the stud for the starter cable.
Has anybody else had similar experiences with this product?
I'll call them tomorrow to see what's up, but I'm probably going to return them. Does anybody have headers that allows starter access without removing them any time the starter needs work? Granted, that shouldn't be very often, but given the tight clearance of the headers around the starter, I anticipate it will be more likely to have troubles given the higher temps it will experience.
Thanks.
the canary.
Thanks.
the canary.
