Joker11
I am wondering about how clocking a transfer case will affect the driveline angle.
If you clock the transfer case up or down, you are going to change the center line of the front driveshaft closer to the output shaft of the transmission in the horizontal plane on the transfercase end. The differential will not move and the driveshaft will have both a vertical and horizontal angle to it.
To move the front driveline vertically up or down would require lengthening the transfer case the appropriate distance in order to not affect the horizontal alignment.
So how do you guys introduce another angle into the driveline without issues??:?
