When I put my combination together, small block pattern, original flywheel, diaphram clutch, cast early large bellhousing, the spring steel flat, return springs?, sticking out the diameter of the 11 inch setup scored the bellhousing enough that I dissassembled and made clearance in the bell housing and evenly reduced the corners of the flat springs.
I attributed it to the 3.8 crank flywheel end being a bit longer. An afterthought.
