clutch problems
1967Ronco
Hey guys! When I was in the military back in 99 i owned a bronco and just recently was able to purchase a very very nice new one. I do have one issue that has crept up I am hoping I can get help with! First here are my specs
351 windsor
center force two clutch
np435 4 speed
Basically it is a little hard to shift into gear and when i get it warmed up and am driving it get harder and harder to where it starts to grind gears and I need to slam it into gear. Once it been warmed up well it wont go into reverse at all without some pushing an grinding.
Also my oil pressure starts at 40 then drops below 20 when it gets going, whats the normal operating psi for a windsor?
As for the oil pressure, need more details first (see below). It's fairly common though, for a slightly older, or slightly "looser" engine, but typically they'd start up in about the 60 to 70 pound range when cold and run down into the 30 to 40 range when hot.
Not uncommon though, to read a bit lower, so nothing necessarily to worry about. Yet!
Back to that 20 psi though. Is that as high as it will go when revved up? Or is that at idle? Basically, the rule-of-thumb is that you need at least 10 psi for every 1000 rpm.
By that then, if you have 20 at idle, you're gold. If you have only 20 all the way up to the higher rpms, then you've got a problem somewhere! Pump? Blocked passages? Faulty gauge or sender? Bad wiring? Not enough voltage coming to the gauges via the IVR (instrument voltage regulator) on the back of the cluster.
Obviously quite a few things to look at. But first thing might be to verify your pressure reading through an independent mechanical gauge hooked to the pressure port. Good start anyway.
As for the clutch/tranny issue, it sure does sound like something with the clutch. First thing I'd do though is change the fluid in the trans. If you don't know it's history, or know it hasn't been done in awhile, get it out of there.
I'd say to put in a medium weight 75w/90 synthetic gear lube. These were made for heavy duty use with from light to heavy oils in them. I just like the thinner synthetic for smooth shifting characteristics.
There are plenty of others here that have a lot more experience with the 435 though, so wait for some of them to chime in and get some more info.
At the very least though, check your fluid level. It's cheap, easy, and a necessary chore anyway.
Oh, and have you adjusted your clutch to specs yet? What? You don't have a shop manual yet? hah! Better get one if you don't.
Oh again. Welcome to the site by the way! Should've said that right up front, but got caught up in all my chattiness.
Should be a fun project.
Good luck. Hope it's NOT the clutch.
broncnaz
Welcome
I'll 2nd the clutch adjustment. Usually shifting probelms are due to a misadjusted linkage. Doesnt really sound like a oil issue but it is worth it to check it out. The book calls for 50W engine oil in the NP435 thats what I've always run here in AZ where is hot. A lot of people do run regular gear oil without issue but it may shift a little harder when cold. I would suggest using a synthectic if going that route.
You engine oil pressure sounds ok should be a little better when at speed though.. What weight of oil are you running and what filter? You might try some heavier oil like 10-40 it might help also old oil doesnt help PSI.
...The book calls for 50W engine oil in the NP435 thats what I've always run here in AZ where is hot. A lot of people do run regular gear oil without issue but it may shift a little harder when cold. I would suggest using a synthectic if going that route.
Agreed. Don't like the heavier oils because of the cold shifting issue. The 50 wt would work well, but the book I'm looking at now (Haynes) lists the recommended lube only as 140w!!!! Yikes. Good lube and cushioning characteristics I bet, but gotta' be one stiff-shifting sumgun in the winter.
Had a lube-guide from one of the oil companies (Pennzoil, I think?) that recommended ATF. Man, talk about the extremes!!!
One of the reasons I liked the 75w/90 synthetic is that it smoothed out the shifting feel several different trans. that I've used it in. From little Toyota 4 and 5-speeds, up to NP435's.
Use it in my D20 also, even though they call for that same 50 weight non-detergent motor oil.
Expensive, yes, but works good. Cheap insurance I feel.
broncnaz
Hayes manuals seem to have a lot of different specs. But manufactures did call for the heavier oil in 435's but Frod called for the lighter stuff.
1967Ronco
thanks all for the info, first some main follow up info.
I have owned it now for 2 weeks and the first thing I did was take it to a reputable classic repair shop and have them replace all the fluids. Everything is now synthetic as well.
Here is what they did and put in
oil change (ams 10/30 hi performance) ams eao-15 oil filter
trans flush and diff flush (2 gallons of AMS 75w/90w gear lube)
brake flush (wil 570 brake fluid) i have disc brakes all around
clutch issue: so it seems it is a linkage problem misalignment? it was what my gut feeling was as well. Anyways, the records he gave me show a bunch of new clutch parts and adjustment in the last few years. I dont have them on me or I would post details.
Oil Issue: Today I drove it to work (20 min drive with my 5 minute stop for gas) to show it off and it started at 40 and stayed at about 30 the entire time. The clutch also wasnt bad it was sticking on 2nd a bit as I got to work but it was fine.
Well, I'm still not completely convinced that something as seriously out of whack as your description is capable of being "only" the adjustments. But they certainly could make something worse!
Certainly could play a part, but I would think that something in the clutch is creating an issue as well. Centerforces are pretty good, but nothing is perfect I guess.
Can't hurt to adjust it anyway. Somebody here'll have the procedure for you hopefully, but sounds like a shop manual is in your very near future anyway.
Hmm, maybe the pivot bracket for the clutch fork is working loose? It's riveted to the bellhousing and can wear out. I wonder if that would contribute to the symptoms you're describing?
Way to go on the fluid changes. Even the brakes. Good.
Can't imagine that good, new synthetic would cause this as it gets hotter. The stuff you're using should be perfect.
Besides, doesn't sound like a tranny issue anyway. Still more like a clutch.
Maybe the linkage is just worn out? Maybe it's not so much the "heat" as it is just the amount of use? Check the general condition of your pedal pivot, pedal rod through the floor, bell-crank (for looseness), actuating rod (pushes the clutch lever) and the lever itself.
Hopefully it's just something on the outside and you don't have to go in and start replacing things inside.
Good luck.
1967Ronco
Thanks for the further info. I am almost 100% convinced its in the clutch linkage. Thanks for the support on the fluid changes, this is the first vehicle i have purchased where it was done complete by someone else...normally i buy em bare so I know where every bolt and screw in it is and how she works.
At the minimuk regardless of its immaculate and detailed work history I was still going to replace every drop of fluid in it so I started off on the right foot.
Oh something I forgot with the clutch problem!
I forgot to mention when it started to get bad yesterday at idle with my foot all the way down on the clutch the bronco would creep forward. I had to put my foot on the brake on it at a dead stop on a flat plane. It was a significant creep too...maybe..a foot a second.
75junebug
NW Houston Tx
As far as the Oil pressure fluctuations, you might try a new sending unit or install a mechanical guage. On the tranny issue, try adding some lucas to the 90 wt oil, it helped mine alittle, but the last time i had the lid off the tranny, I noticed the plastic riders on the shift forks were missing.
I like Lucas too, but this is not a tranny issue. Not shifting, grinding, not wanting to go into reverse at all, and then finally doing 'the creep" is all indicative of a grabbing clutch.
If I didn't know better (which I don't of course!), I'd say that your PO replaced the clutch mechanism with a hydraulic unit. Classic case of hydraulic slave-cylinder bleed-down.
You have a modern 5-speed ZF or NV transmission in there by any chance? Fuel injected engine with newer block?
Even if not hydraulic, your linkage is stretching or pulling something so that your clutch is not disengaging. Could it be the clutch plate itself? I suppose so, but someone with more clutch experience will have to say. I've never seen one drag that wasn't linkage related. Slip? Yes, Drag, nope.
