Clutch spline grease
Bitch'nBronco
Loose Cannon
Ringwood, NJ
It's been about 12 years since I swapped a clutch, is there a specific type of grease to use on the splines of the transmission? I was going to use a light coat of red bearing grease, but wasn't sure if it's too viscous (don't want it to spin out onto the clutch surface).
Does the inside of the pilot bushing get a thin layer of grease as well?
Is red loctite on the flywheel bolts good enough or do I need a different type of thread sealer to keep oil from leaching out? (My crank bolt holes go all the way thru the crank).
Anything thick and with a high temperature rating I would think. But the key is what you mentioned, a very light coat.
Not enough to spread out even if it tried.
There is probably a product that is both a thread locker and a sealer, so look for that first.
If not, then the lock part is probably more important than the seal part. Of course, I think both are equally important.
It’s great when your fly wheel bolts don’t come loose, but nobody wants to deal with a leak either!
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Ringwood, NJ
Thanks Paul, I'll get some brake parts grease and use that. I think this red bearing grease is going to cause me problems.
Apogee
Tangent, OR
I used red Loctite on my flywheel bolts, no issues. As for the splines, I just used some high-temp wheel bearing grease I had laying around, again with no issues.
Now for the pilot bushing, if it's an SAE Oilite bronze bushing, you don't want to put grease on that, but rather SAE 30W oil. You can't really properly lubricate the bushing without removing it, heating it up and then quenching it in an oil bath, so most just run them until they die and replace them when it's time to do a clutch. In certain industrial applications that used Oilite bushings I've dealt with in the past, I remember the standard maintenance protocol being to lubricate or replace every 1000 hours or 1 year, whichever came first, but I don't do that with my pilot bushings...they're ride or die for life.
Rustytruck
when greasing the spline only grease them from the node to the wear marks on the spline and no further the clutch disc doesnt move very far greasing any further will prevent rust but your only greasing air. Lubriplate is good for this and outer parts in the hub where the splined components are. Ford used allot of this stuff back in the day.
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Ringwood, NJ
It's in, got the trans in as well. I'll get it back on the road this weekend :) thanks for the help
jeffncs
Raleigh, NC
I know you’re already beyond needing this info…. but anyway…
Light coat of moly grease on the input shaft
I have had dozens if flywheels off and NEVER use red loctite. Thats virtually a permanent bond. I used blue almost exclusively and never had an issue.
I hope you never have to take it apart again…. Seriously.
