clutch squeal?
Shimmy
1977 Bronco
Maple Valley
i started experiencing a slight squeal at idle. i noticed if i just put the weight of my foot on the clutch pedal (not even really pressing it) the squeal goes away. do i need to adjust my clutch rod or is there something else i should also check first?
previous owner said the clutch was recently replaced and i've only put about 500miles on the bronco.
stock floor 3 speed
Well, I hate to say this.. so I won’t!
Instead I’ll say first to double and triple check the adjustment. There should be enough FreePlay so that the throwout bearing does not constantly ride against the pressure plate.
If it’s even barely touching you will get a very short life out of it.
Most t/o bearings are designed for no more than a few hours of actual rotation because they are normally in a non-spinning condition. If they are stuck up against the pressure plate spinning with the engine any time it’s running, your throwout bearing will only last a short time.
Such as about 500 miles.
So first and foremost get that thing adjusted if it’s not. Then let’s check other possibilities.
There’s a subtle difference between play in the linkage, an actual gap between the bearing and pressure plate.
You have to separate those and make sure that the little bit of play at the pedal is not just looseness and tolerances in the linkage.
Shimmy
Shimmy
1977 Bronco
Maple Valley
that was thinking too and yah... i consider the TO bearing and just wept on my pillow last night
Well the good news (as far as I’m concerned at the moment until we determine otherwise that is) is that because the squeal still goes away when you press the pedal it means the bearing is still at least slightly serviceable.
When it starts squealing with actual pressure on it from your foot, then the bearing is gone.
Or if not squealing if it rattles or you feel the vibration through the pedal, the bearing is on its way out.
But the squeaking until pressed still means you have a little life left in it to play with.
Making it all that much more important that you adjust a little more FreePlay into the system as well as make sure that all the components are working as expected.
This means making sure that the clutch fork is not bound up or loose, or otherwise allowing the throttle bearing to touch. And that the bell crank on the frame, pedal pivot, rod and any other bits of linkage are in good working order.
Yours isn’t the one with the missing spring by any chance, is it?
There was a discussion just last week or two of a loose clutch release fork.
Shimmy
Shimmy
1977 Bronco
Maple Valley
Update! I adjusted the clutch rod in a little and it appears to have fixed the squeal. I noticed my clutch spring is attached to the frame itself with potentially not enough tension. The previous owner installed TBP SS headers, so he hooked the spring into the frame as shown in the pic.
Can someone verify that the red circled hole is the stock attachment point on the motor mount. If so, i'm thinking i'll drill a tiny hole at the yellow arrow location and pull the spring back to this location. looking for a little more tension in the spring to keep the clutch fork pulled back.
EDIT: nevermind. i just shortened the spring and that'll work
