Clydesdale Buildup (heavy horse)
regshawn
Portland
Why? Sorry for the hi jack!!!
Cory,
It sounded cool, and people are having great success, but.....Just not my thing. As a matter of fact the motor was still at this place a while back when I was there. What's the weight difference between the 4BT and a 351W, anybody know?
Shawn
swa0330
Portland,OR
About 200-250 lbs heavier for the 4BT. Cummins lists the weight at 750lbs. I understand a built 351 is about 500
regshawn
Portland
Thats not to bad of a difference, you could cut weight other places.
Back to the Clydesdale build, are you guys making a custom flat bed for that BB (Bitchin Bronco)?
Shawn
regshawn
Portland
Ya, whats the deal? Explain what your gonna do.
Cory,
Just putting a DD together for the wife right now. Basic low budget frame off:cool: , 302, C4, disk brakes, Dana44, big bearing 9", 4.11 front and rear w/ lunch box lockers, hydro-boost, family cage, etc... Then I will build a trail rig, just not sure on what setup yet. %) ;D
Shawn
JB Fab
JB Fab
Well,
The idea was to build a flatbed, you know, an aluminum number w/ stake pockets.
But as soon as I drew the rig out with an exo, I knew I had a truggy, so that is the way we are going.
Jon
JB Fab
JB Fab
Motor mounts
We knew that it would be a balancing act to figure out the height of the motor, especially since the turbo is a high mount now.
We needed the oil pan to clear the high pinion on the axles that we wanted to use, but we still didn't want to block our view with the turbo, or make it any more susceptible to damage in a roll-over.
We ended up using the P30 type liquid filled mounts oriented straight up, since that method has come highly recommended by people that know more about these motors than I.
Jon
JB Fab
JB Fab
Axles
Here is why we are concerned about the pinion clearance.
Mercedes Unimog 404 axles....
Mtn Gote
Sultan Wa.
Geez!!! First the cummins now unimogs!! This is going to be a MONSTER!!!!!!! I am loving this build! Good job man!!!
Cory,
JB Fab
JB Fab
Checkin' the hood clearance
Looks like we won't need the middle of the hood....
JB Fab
JB Fab
Brakes
We know we want to run standard wheels, and we will need to upgrade to disc brakes, so we got the disc kits and pinion conversions from Mac at Exaxct Axle.
Outstanding workmanship on the disc kit.
New hubs come with the kit (8 lug ) so we will be running Hummer H1 wheels, with the H1 offset to decrease our scrub radius. Since the portal box puts the hub face farther from the point of rotation that a typical front axle.
JB Fab
JB Fab
Air locker
Quick and easy air locker. since the 404 axles have a cable actuated locker, the linkage was modified, and a small ($17) spring return air ram was added.
JB Fab
JB Fab
Tubes
Since tube bending was going to required in the near future, I went in with a couple of friends and built some benders.
Here is a link to the bender thread, you can find out all there is to know about these cool, easy to build benders.
http://www.pirate4x4.com/forum/showthread.php?t=376183&highlight=tube+bender
Note:
Bender shown bending 1-3/4" .250 1026 DOM (design limit unknown)
JB Fab
JB Fab
Wheels and tires
For the wheels we are using H1 military Humvee wheels (not having them re-centered).
We added the Dean Reed inner double bead locks, and Dean's "Rock-Rings" rim protectors. We had them powder coated in low-gloss black since that is to color this rig will end up being when it's done.
pmctighe
Jon
How far down the frame rail did you go for the mounts? (from the top?)
What is the height difference between the Unimog and a HP D44? Best guess.
How much lift? Suspension? Body?
How far is the Turbo sticking out of the Hood?
I am trying to learn from you for my Cummins conv. any help is appreciated.
