Hi, there should be a washer and then the cotter pin on the z bar linkage.
There are two rods, one from the clutch pedal down to the z bar, and the other from the z bar to the fork.
This last one has a heavy spring and the adjustment threads.
You may as well check all the cotter pins and washers.
And lube all the moving parts with WD 40.
Good luck
Good luck
