Combining Fuel Tanks
turbotim2
____________
Except for being DOT illegal if its not diesel fuel.
Once upon a time it was done with boats too...the use of a balance/gravity transfer tube between more than one fuel tank. Now its illegal for boats too; you are only allowed to 'gravity' or 'bottom feed' from a very small day tank in the case of diesel vessels, and must have a postive 'above level' pump transfer system to fill the day tank, and no bottom transfer or feed of any kind is allowed with gasoline tanks.
They are 2003 & 2004 gas jobs with the 496's. Like I said, I don't know how it is done as far as plumbing goes.
bmc69
The OP was proposing simply gravity-balanced via a transfer tube; at least that is quite clearly not DOT legal since the tank connections would/could clearly not be above the maximum full fuel level.
Not sure what other method could work without a transfer pump in line.
broncnaz
I believe the gm trucks have a balance pump that turns on once the main tank ie front tank has used 1/4 tank of its fuel. Its contoled by the sending unit kinda just keeps the fuel at a constant level after that.
jim3326
Appleturkey
Or..don't try it because its....illegal to do so with gas tanks. From DOT regs:
(5) Fuel withdrawal fittings. Except for diesel fuel tanks, the fittings through which fuel is withdrawn from a fuel tank must be located above the normal level of fuel in the tank when the tank is full.
This means all of our old original tanks and some of the replacements are illegal then.
Jim W.
bmc69
Jim W.
That is actually very true. I believe that the rule in question went in to full force in '73...I wonder how Ford skirted that with the EB tanks from '73 to '77?. It's not at the bottom..but its certainly not 'above the max fill' point either.
broncobilly72
I have 3 tanks all switchable. More than once I have not paid attention to my fuel gauge and have ran a tank dry. Solution?....switch to one of the other tanks and start looking for a gas station. Hooking all the tanks together I would have been stuck.
