combining wiring form new tech to old tech???
POPPAWS BRONCO
Horn Lake, Ms.
Need some technical advice before i go chopping on wires in my harnesses. I am currently installing a FAST EZ EFI 2.0 Multi port injection on my 77 Bronco with stock 302. New EFI brain wants and needs to see every thing related to fuel pressure, air, O2, and coolant temp. The Kit came with new sensors for the new brain to monitor and control things correctly. I'll have and be able to read all this on the control unit for the FAST system. Factory connectors don't match modern connectors. My question is with new sensors that came in the kit can i just tie my wire into say the engine coolant wire so my factory dash gage reads as well. or is the new and old tech speaking different language so to speak?
pcf_mark
EFI needs nice electrically clean steady connections. I built all new wiring just for the EFI. The only connection to the Bronco wiring is 12v from the key switch to trip a relay that turns on ECM power relay and fuel pump relay. Then I have separate 4 circuit sub fue panel that supplies power to everything EFI (injectors, IAC etc). The Bronco wiring is just too weak and fragile for EFI after 40+ years.
Leave all your factory sensors in place (they will NOT work with EFI) then install new sensors for the EFI in different locations. You only need to add coolant, intake air temp, MAP I believe with FAST.
POPPAWS BRONCO
POPPAWS BRONCO
Horn Lake, Ms.
Kit came with new wire harness. New manifold everything. Just realized my coolant temp wasn't gonna plug up anymore. I've got everything installed. Almost
I'd have to pull it all and take manifold somewhere to be drilled and tapped for a second coolant sensor.
There's another option that might work. A new thermostat housing with the threaded hole in it already. Like this one we sell: http://www.wildhorses4x4.com/product/Thermostat_Housing or if you nee the later model EFI style with more of a 90 degree bend, that's available as well I think.
Are you sure too, that there is not at least one extra port maybe behind the carb flange? Yeah, many manifolds only have the one like in your pic, but most I think have a second one somewhere.
Good luck.
POPPAWS BRONCO
POPPAWS BRONCO
Horn Lake, Ms.
The unplugged port seen is the bypass for coolant to the heater core. The old one was bent and crusty looking so I wanted to replace it. There are two flat spots in the rear of manifold that could be used. I looked at that same therm housing donk. Didn't see a size of that plug and it looks smaller than sensor. You think I could drill and tap and use a shop vac to suck out anything that fell down during drilling? Otherwise at this point I'll just use the digital readout till I pull the motor at a later date.
It's definitely small, so some sensors might not fit. But it's the correct size for some, so I can't say for sure with yours.
I believe it would fit the stock temp gauge sending unit though (we can verify first) and then you could use the old larger hole for your EFI coolant temp sensor.
POPPAWS BRONCO
POPPAWS BRONCO
Horn Lake, Ms.
Thanks it's worth looking into for sure. This is my first time really modifying anything to this level. While it's not been hard. It's left a lot of little things to be done to make it all work. It's definitely not as easy as 1 2 3 GO. I know it will be worth it in the end. Truthfully it's been fun so far.
Georgelas
Vienna
I just did this on my EZ EFI. Thermostat housing works great. Note this is the steel housing not chrome.
POPPAWS BRONCO
POPPAWS BRONCO
Horn Lake, Ms.
Thermostats housing it is. Thanks Mark
In other news me and the wife got the throttle Peddle assembly out so it can be modified for new cable style set up. Let's just say that was fun. Removal of doors, seats, and steering wheel should be done before you attempt to work under the dash. She was a trooper hanging upside down with the blood rushing to her head.
nvrstuk
PNW
isn't the coolant sensor supposed to be sensing engine coolant temp before the t-stat? Putting the sensor in that 3/8NPT housing location wouldn't allow current temperatures to be read unless the t-stat was open.
I drilled a 9/64" weep hole in my t-stat so it would bleed thru some water to the sensor and hopefully give an accurate temperature reading to the ECU.
POPPAWS BRONCO
POPPAWS BRONCO
Horn Lake, Ms.
You are correct but since I will have a digital read out too on the FAST hand held I won't fill like my factory temp gauge is totally useless
