IronBenderII
- Nov 27, 2002
- 686
I think you need an East Coast tester!;D
Isn't Montana the East Coast? Ha ha ha.
Jack you..Trevor, you're going to have to wait ill after SOB so I can maintain my upper hand
Jack
That is going to make such an amazing difference right there... You'll wonder how you were ever able to land w/o them!
Jack
He's talking about the Static-X Bronco but I don't think that's Orange, I think it's Blue. But no, never had the Poly setup.
Their setup seems to be a solid design and should work well. Only advantage of their kit is it will be less expensive, but you don't get as much either.
Advantages of ours...
1. It's complete - comes with shock hoops and mounting for coilovers. I has a mount for the upper links (you have to build something w/ their kit). It will also have a bump stop option (nitrogen) and a sway bar option that is adjustable.
2. You can use coilovers w/o having them come up through the tub.
3. It's adjustable (upper link adjusts for different Bronco's/lifts/terrain)
Jack
How is the hell am I going to tune this thing. No Directions!!
I understand rebound and compression, but why is there two compression adjusters?
Are these air or nitrogen? It says 150 psi on the ends. Can we play with pressure too. Any info here?
Wait, wait, wait...you bought a set of bypass shocks and you aren't sure how to tune 'em yet? Well, don't worry...we can straighten you out! The whole point of a bypass shock is to have position sensitive damping. The external tubes on a bypass shock allow fluid to flow around (bypass) the main piston. There's a one way valve in there that only allows fluid to flow one direction, and the amount of resistance to flow is adjustable on each tube. The multiple tubes set up different zones...lots of bypass in some zones, typically going to none at full compression (so all fluid flows through the piston). Hopefully that makes sense...
Nitrogen gas - and no, it's not a tuning feature. The only time you tune with air is in an air shock...
Sorry for the threadjack!
