Hardpivot
- May 13, 2013
- 24
Hey guys,
Recently I pulled my 9" rear diff apart to do a partial rebuild. I didn't touch the locker or the carrier bearings, but I did replace the bearings on the pinion gear. When I pulled the pinion housing off, I noticed there was no seal between the it and the axle housing, just a shim. Now that I've put it back together, Its leaking from that spot and it didn't before. Should I have put rtv between the joint with the shim?
