Unfortunately it's going to vary quite a bit by the particulars of the engine, but I would say that you're looking for consistent readings between 115 and 130 psi on a stock-ish engine, and maybe 140 to 180 on a modified one.
Things that make a difference are mainly cams and combustion chambers (heads and pistons) and intakes and exhausts.
Always do the test with all plugs removed, and the carburetor or throttle body wide open. All you're looking for at this point is a very small variance between all cylinders.
