MattNelson
- May 1, 2014
- 37
I have been getting some oil and white smoke coming out of both the valve covers, getting into the line from the oil cap to the air filter housing and probably into the carb. So, to start, I did a compression test. This is an I6 170 here, so don't be surprised by a couple missing cylinders:
1 - 170 psi
2 - 170 psi
3 - 170 psi
4 - 170 psi
5 - 150 psi
6 - 85 psi
It's an all stock 1969 Wagon with 26,000 original miles. I know - I thought that was unbelievable, but the factory cylinder pressures are 175 psi, so the 170 psi readings pretty much validates the low mileage of the Bronco. I've driven it over 100 miles and had a sustained top speed of 62 mph. Considering the factory top speed was 85 mph, I say it's not too bad.
Some other troubleshooting I've done:
So, my question is what's next? I read this article about compression testing http://classicbroncos.com/forums/showthread.php?t=87199 and I'm really hoping the answer is something other than bad rings and a full rebuild, because frankly, I'm wondering if that's even worth it on a 170. The technical article says that any of the following can be causing low compression:
How do I verify it's a valve problem or something else I can remedy without pulling the engine? Are there any other troubleshooting steps I can take to narrow down the issue or confirm it's a bad piston or piston ring?
I know this might be a basic question to some of y'all, but this is my first real engine work and I'm new to this. Thanks for the help! ;D
1 - 170 psi
2 - 170 psi
3 - 170 psi
4 - 170 psi
5 - 150 psi
6 - 85 psi
- Looked at the PCV valve - it was filled with oil. Replaced with a new one, it quickly filled with oil.
- Captured some of the white smoke with a water bottle to see if it condensates (leaking head gasket) - no condensation.
- Looked at the oil and coolant - no sign of cross contamination.
- Smelled the exhaust - no sweet smell signifying burning coolant.
- Burned Valve
- Burned Valve Seat
- Physical Engine Damage (Burnt valve, Hole in piston, etc…)
- Blown Head Gasket
- Worn Rings or Cylinder wall
- Valve Train Troubles (Incorrectly adjusted Valves, broken valve spring, etc…)
- Jumped timing chain
