- Mar 20, 2008
- 1,249
Just installed a B&M deep pan. So the original capacity was 11 qts. whit new pan add 2 qut for a total of 13 qts.
(torque converter drained too)
O.K. added 4 to the empty pan. started it up for a few seconds sutit down. added two more (total 6) Started it up, went through the gears, kept it running added 7 qut more. (total 12, 1 under ideal) went for a ride. Through the gears, in reverse a few times went home. Truck is up to temp.
Check the dipstick and its 4" higher the the "Full" mark and fluid is pissing out the top vent.
O.K. whats up? do I drain some or let it settle (engine off)
Or run it at a high level?
reamer
reamer
