g8rb8t
- Feb 23, 2008
- 1,476
Hey guys -
Getting deeper into the mechanical side of my truck and learning a lot as I go thanks to this board. Recent update is last year or so I replaced my radiator and upper/lower hoses. The truck has been running great ever since.
Yesterday I noticed a coolant leak at what I thought was the bypass hose and replaced it ('74 302 and as I understand coolant capacity is 4 gallons).
A few items I noticed:
1. Draining with the radiator cap removed only yielded approx 1 gallon of coolant, expected a lot more?? Got the hose replaced and it only took just over a gallon to top off the coolant... Any ideas why it tops off with only a gallon?
2. After replacing the hose and topping off, it appears the leak is in the gasket where the bypass hose connects (Thermostat housing). Wondering if I should just replace the entire housing with a cast Thermostat housing or just go with a new Thermostat gasket? See the attached picture for the drip location
Thanks for thoughts.
Sent from my SM-G996U1 using Tapatalk
