Coolant Overflow Bottle Cap Sweating
NewDog
Surrey BC
Hi, any ideas on why this is happening?
My coolant overflow bottle cap seems to be sweating or something. Coolant is appearing on the top of the cap. Not sure how it ends up there. There is a really tiny pinhole in the top of the cap, could it be escaping through that?
Definitely it doesn't leak where the hose goes into the bottle. Not a whole lot seems to come out at the cap, but eventually some does run down on to the fender, but usually only a few drips worth.
Have a crate 302 with a C4 auto, generally it runs at about 190-200 once it's up to temp.
Thoughts? Appreciate any input.
David
NewDog
NewDog
Surrey BC
hmmm... Maybe it is more than just sweating a bit. Noticed coolant was dripping through the strap bolts that mount the bottle to the fender. When I pulled the bottle off, it was pretty wet underneath.
Bottle doesn't seem to be cracked or leaking, nothing obvious anyway.
But the overflow tube was right near the top of the coolant level, so thinking maybe it is spraying around in there a bit, and leaking out the cap? I shoved the overflow tube deeper into the coolant, so now it's near the bottom of the bottle.
Gonna go for a spin and see if anything changes.
jckkys
The top just snaps on and is loose. So steam or expanding gas can escape under the cap easier than a pin hole in the cap. I can't see a reason or explanation for coolant on top of the cap. Try sticking some paper towel pieces in suspected leak sources after shutting down a hot engine. Then look for wet spots. The hot soak has higher temps and pressures.
I stuck a 3/8" steel tube inside the hose that extended to the bottom of the tank so the radiator can draw all the coolant out of the tank when the engine cools. Coolant can't do any cooling in the over flow tank.
NewDog
NewDog
Surrey BC
Took it for a spin yesterday, same mystery leakage.
Cleaned it all up tonight, then just ran it in the driveway with paper towel sitting under the bottle and next to the cap. Heated it up to 200F then shut it down. Heat soak then pushed it up near 220F and the bottle filled up to "hot fill" line.
No leaks visible so far, although it hasn't completely cooled down yet.
I suspect the cap is just getting old and weak (it seems to sit on there pretty loose) and so maybe it leaks when coolant is sloshing around out on the road. Not sure how tight the cap is when new.
jckkys
A new one will fit loosely too. It's not a pressurized tank like new cars and trucks.
Make sure your tube is very close to the bottom and make sure your radiator cap is a proper return type cap and make sure you are not over-filling either the radiator or the bottle when it's cold.
Even with a good radiator cap, with the tube at the top of the overflow/recovery bottle the hot coolant was being pushed into the reservoir, but was not able to be sucked back in. Therefore every time you drove it the bottle was filled more and more and was literally overflowing.
That's one possible scenario anyway. If the radiator cap is not functioning properly the coolant might not be getting pulled back when it's cold either.
You can verify either of these conditions by monitoring the level in the overflow tank.
By over-filling it could be doing the same thing.
But normally there is a drain that should be letting out any excess under any of those circumstances, before it gets pushed out the cap. Isn't the one on the Bronco just a simple J-shaped nipple thingy sticking out the upper area of the reservoir? Maybe on the back facing the firewall? I've never had one so am not remembering correctly perhaps.
I just looked at our pics and I don't see the overflow neck. I wonder if there isn't one, in which case the excess would have to come out the cap.
Anyway, check the level when cold and don't fill the radiator to the cap. Leave it at the bottom of the neck and see if you still have the same issue.
The tiny hole is a normal vent hole. Keeps the cap from blowing off as fluid expands to fill the bottle. The loose fit lid can still seal a little bit.
My best guess, splash. It does fine sitting in the driveway because you are not moving. No go drive and the coolant will slosh around and splash on the bottom of the cap. Everything wet, add a little thermal expansion.
NewDog
NewDog
Surrey BC
Thanks all for your input.
I took jckkys' advice and put paper towel underneath it, all around the cap and under the fill tube and took it for a good spin, and it leaked, like Broncobowsher predicted.
Seems like it is mainly leaking out around the cap, since the paper towel was most wet at the rear of the cap, with a wee bit underneath the fill tube too.
Nothing under the tank itself.
To Paul's points: the hose is now pushed down to 1/4" from the bottom of the tank. It is a new rad cap (Stant 10329), and the coolant in the bottle is right on the cold fill line when cold, and when the rad pushes out coolant into the bottle, it doesn't fill much higher than the hot fill line - maybe 1/8" above it at most. It seems to suck it back into the rad OK too, this morning it was right back down at the cold fill line. There is no overflow thingy on the bottle, pic attached.
Re: not overfilling the rad, where should it be at? It is now right up to the rad cap when cold.
I am running a WH 4 core triple pass rad, if that makes a difference to any of this.
Thanks,
David
Good test results. Sounds like it's not an issue with over-filling then. Just the splash like was described. But it's still not a common complaint that I'm aware of. Maybe others have had this experience, and just not mentioned it.
Any others out there?
When cold the old recommendation was something like 3/4" below the cap chamber. Which is also fine, but really it does not sound as if this slightly higher level is causing a problem. It might if you had a smaller aftermarket reservoir, like I've seen in some cases (like some of the small tubular aluminum ones), but not in your case.
The Triple-Bypass (my name for it) is a great setup. Should not be creating any differences for purposes of this discussion.
aaronhooker
London
coolant overflowing
I read a few answers but none of them mentioned the thermostat. In my experience, the thermostat is the most likely cause of the overflow tank to overfill. The fluid is being blocked therefore it's heating up to the point of actually boiling and then as it expands and the only place for it to go without causing a leak in the system is into the overflow tank and then overflowing out of that tank. If the problem is not fixed quickly you're going to experience a leak somewhere else in the system.
Good thing to mention! Thanks
And welcome to classicbroncos too!
But in this case it's not over-filling at all as the tests showed. It's just moving up and down the proper amount within the lines.
But while it's not over-filling, something is still causing the fluid to drip out of the cap. Sloshing seems the most likely thing, but would not explain why so many others do not experience it. Just a fickle nature of the design of the cap maybe? Don't know, but we sure hope it's not an over heating problem.
Of course, if you keep your eye on the TEMP gauge you can easily rule that out. Presumably you watch your gauges like the hawk we always had to do with older vehicles.
NewDog
NewDog
Surrey BC
DirtDonk;3298458 But while it's not over-filling said:
Thanks Paul, and welcome aboard aaronhooker.
Yes, it's not overflowing out of the bottle, it stays between the cold and hot fill lines - I would guess maybe a tablespoon or two or three is sloshing out from under the cap. I do watch the temp like a hawk and generally it runs 190-200, rarely might go up to 210 in stop n go traffic.
My latest guess is this: The hole in the cap is really small. I can barely even see it with my old eyes. And the cap is really loose, it only takes a slight touch to pop it open - I think the plastic is probably getting fatigued. So I think that when the hot coolant comes into the bottle, the air in the bottle needs to escape faster than what the little pinhole can allow, and so the loose cap just partly pops open. Then with the coolant sloshing around in the bottle, it just sloshes out the (now extra loose) cap. When things cool down, air goes back into the tank and the cap settles back in place. Loosely, but in place.
So now to test my theory, I have ordered a new bottle (with a new cap of course).
Thanks for all the input, will keep you posted.
David
NewDog
NewDog
Surrey BC
Problem solved. Installed new bottle and cap. The cap snaps on much tighter than the old one, but is not airtight. Not leaking anymore and looks good too.
Thanks all for your input!
David
ND BRNCO
I’m a little late to this party, but wanted to share I’ve had the exact same experience with that bottle. Glad to hear the new bottle and cap fixed it for you, NewDog. I’ve been trying to come up with a cheap fix like some kind of gasket or rubber around the opening to help the old cap seat better, but also create a vent to allow the bottle to breathe. Haven’t tried anything yet tho.
Rustytruck
The cap is designed on the recovery bottle to pop off in a coolant over heat surge. much safer to have the cap pop than the bottle explode. as for overfull the whole point of having the over flow bottle is to keep the radiator full to the top. if your cooling system was working properly the overflow bottle system would purge the air out of the radiator system and replace it with coolant as the engine goes through heat cycles. then once the system is full the level in the bottle needs to be at the minimum line. the old down the radiator coolant level goes back to the days of no recovery bottle cars when the overflow was allowed to dump on the ground that pretty much stopped in the mid 60's.
jckkys
I had a reason to state that a new cap would make no difference and that is that I did it. These aftermarket bottles come with a black cap. The OEM bottle came with a red cap. I got used to the red cap and the black one didn't look right. So I bought a red one from Dennis Carpenter. All these parts are new being part of a frame off restoration. There is no difference in the fit between the 2 caps. Both are equally loose and there is no pin hole in either one. A tight fit would just result in it blowing off. The hot air/steam escapes from the loose cap easily. I know this kills a few theories, and I don't have a new theory. I can't duplicate the phenomena so far.
