Cooling experts. Please advise
77bronco_ed
Hey guys not my first post on the issue. I see supercharged and blown engines on hot days cruising so there is no reason I should not be able to drive a mostly stock fiberglass bronco in 95 deg weather without heating issues.
Since it sat so many years I drive the thing ;) Cooling system has never been quite right.
early spring heading home on a 4 hour drive, as temp started to get into the 80's I had to baby it home. 4 hours took closer to 8.
I pulled the front of the motor to replace the water pump with a "high flow that I bought from someone on the forum that switched to a serpentine set up.
I was hoping that would solve the problem. Nope.
After reading about failing thermostats I drove for a week without one- Nope
(with cap off water is definitely flowing)
I have a highflow 180 mr gasket thermostat in now.
After reading about the importance of timing I checked and set to 10deg BTC-Nope
After reading about carb settings to lean I pulled a plug. (I changed plugs,wires,etc last fall) Plug seems brown not white. i will post a pic maybe an expert can have better look at it. Is this to lean? I think it is showing the signs due to overheating. sides are metal not white.
Today I purchased a infrared thermometer. Hold reading on area of gauge sensor it matches gauge reading.
Hold for reading at top radiator hose and bottom radiator hose there is about20 30deg difference. Hold reading at top of radiator ribs and bottom of ribs there is 20 30 deg difference sometimes more. How much heat dissipation should be expected? Cooler water is going into the block, should it be cooler than 30 deg?
Derail mechanical fan, spaced about 1.5/2inches from radiator.
paper test is fine
I moved my trans cooler to see if opening up some space would help.
I added straight water and a bottle of the wetter water.
it is an older aluminum radiator with plastic shroud. (I am not a fan of the plastic shroud) this could be better but I have one...it was purchased from a local vendor. The radiator appears to be cooling the water down, should it be doing a better job?
I read another thread in which the fellow recommended advancing to detonation (I assume back off slightly afterwards)
I have nothing to lose.
Its basically stock, headers, coil, heavy amp alt (new belts, not slipping)
more experimenting with timing may be easiest at this point.
I also have read about wrong gaskets blocking passages. Heck should I pull the heads?
What pressure should radiator cap be rated for?
I really want to get to the root of the problem...
ANY input is appreciated
77bronco_ed
77bronco_ed
also rigged a plastic bottle for catching overflow.
Looks like cap is 13lbs should I find one rated lower?
-Ed
77bronco_ed
77bronco_ed
fan is close to touching bottom of shroud. Shroud is made for year of bronco from vendor as well as fan. Possibly angle of photo makes it look odd. I will look over tomorrow.
I think it is a replacement similar to original. I am not pleased with it, if anything it may be slightly off center and exaggerated by angle of photo.
Thanks for comment...
jw0747
San Antonio, TX
Your post talks about heating issues but you didn't mention the engine temps you're experiencing. Some folks talk about bad heating issues when the gauge goes above 190, so let us know what your gauge reads. We really can't tell what it's doing w/o you providing the temps.
13 lb cap is a good choice.
Show Links
Bakersfield
I fought some heat issues and finally resolved them. I like starting with some certainties, like a properly operating radiator and a flushed block. The first thing I did was thoroughly flushed my block, had my radiator flushed and pressure tested at a reputable shop and thermostat replaced with new 180 degree Robert Shaw thermostat. I filled with 50/50 mix, added wetter water (I doubt that made a difference) and made sure my stock fan was operating and situated properly within the stock fan shroud. I also made certain the overfill tank was hooked up correctly. I'd start there and document changes.
I also did a full tune up including plugs, rotary cap, and wires, fluids, etc.
Is that a stock fan. It looks a little different than stock, but I may be wrong. If it is not stock, I would strongly consider replacing with a stock fan.
I have found that there are quite a few opinions about how to read spark plugs. What i do know is that you should be looking at all of your plugs. From what I've read, your plugs have slightly too much timing, but I'm no expert. I included a chart below. I would consider changing to standard Autolite 45s gapped according to either Dura Spark gap of .044 or points gap of .035. It depends on what you have.
Just a few thoughts.
Crawdad
I'd take your radiator in and have them clean it out. I had a 351W over heating a few years ago and decided on replacing water pump with a Flow Kooler ($90) water pump and replaced stock radiator with a Champion three core aluminum radiator ($225 delivered). Ran fine down here before selling bronco. Hope to do same setup in future. Good luck!
pbwcr
The acceptable standard for a mech fan is it should mount ~half in/out of the shroud. The fan should have 1" clearance or close to 1" from fan tip to shroud, and fan centered in shroud. Make these changes and report back.
If you do not have metal fab skills then get a ford shroud and cut it apart and fiberglass it back together to meet the above criteria.
If these changes do not fix overheating then start looking for motor issues.
blubuckaroo
Grease Monkey
Ridgefield WA
Also, I just noticed the back of the radiator looks like the fins may be plugged up. Probably not enough to cause all your problem, but that's the way overheating is a lot of times. Several issues, together creating a bigger problem.
77bronco_ed
77bronco_ed
if sitting it will creep up to 230. I have not been on freeway since since slight timing change and adding wetter water.
77bronco_ed
77bronco_ed
Is that a stock fan. It looks a little different than stock, but I may be wrong. If it is not stock, I would strongly consider replacing with a stock fan. I have found that there are quite a few opinions about how to read spark plugs. What i do know is that you should be looking at all of your plugs. From what I've read, your plugs have slightly too much timing, but I'm no expert. I included a chart below. I would consider changing to standard Autolite 45s gapped according to either Dura Spark gap of .44 or points gap of .35.
I was looking at my older posts on heating, and I have to say time flies. Back in 09 I added the 6 blade 17" derale fan and plastic shroud. set timing at 8 deg BTDC. It was much better than the electric fan set up that was on.
and solved the issue at the time.
So... I have been driving it a while ;)
I just did a tune up with wires,points plug cap,etc when running into an electrical issue. which after 3 days trouble shooting turned out to be a corroded connection.
I think I may have had a sticky thermostat that started my issues recently. With that said, I think time and daily use is now a factor here.
77bronco_ed
77bronco_ed
As mentioned to the other individual that responded... I now realized how time has passed ;) and some of the items may not be working as efficient as they once were.
I definitely agree with the "several issues" may be in play here. I will get the fan a bit closer to the radiator and either make or buy a better fitting shroud as a start. flushing out system and testing radiator is probably a good option at this point. My radiator bought new is probably 15+ years old yikes....
FlogginHarvey
Wichita
Having similar issues here after a rebuild and stroker 331. Flowkooler, Ali 3-core, and just swapped froma 17" fan to an 18" and swapped out a "standard" steel " flat-backed" shroud to the Ali Ron Davis with the full 360* "ring" around it and taking here for a drive tomorrow in 100+* Kansas heat. We will see...my wife loves when I throw more bronco money at SweetPea.;) cough cough
77bronco_ed
77bronco_ed
Yea right stroker similar ha... that is a nice shroud you picked up... you have ron davis radiator to match? there goes a few coins. Good luck hope sweetpea stays cool for ya.
TonyPDX
I think you have a lot of room for improvement on the shroud and fan. I would look for a larger diameter fan with more blades and a higher pitch width.
Of course if the radiator air or water passages are plugged not much will help.
I would loose those spark plugs also, all that extra electro material is shielding the spark from the fuel/air mixture.
gr8scott
You sure that's a bronco shroud? Looks way too big. Fan looks a little small as well, and that radiator has seen better days. Here's mine.
77bronco_ed
77bronco_ed
Guys I think you hit the nail on the head... Today looking at the position of my fan to radiator I see that when I put things back together the fan position is off. Granted it was never directly in center but it was not this far off.
Initially I think my thermostat went... Then putting it back together as i did caused issues.
I now have it centered to the radiator both horizontal and vertical. I also moved it forward slightly. I now just to need get it mounted again. I am excited I am sure this is going to make a big improvement. It was definitely off...
The fan is exactly the size of the fins available on the radiator both top and bottom. It was overhanging on the right side over an inch.
Thanks for all of the feedback, I'll have to wait for the new hangers for the radiator as the ones I have are in bad shape. But I am thinking this is going to resolve much of the issue. I am trying to decide if I want to make or buy another shroud but even with the plastic one I have it fits much nicer. I would like to seal it up good so that it sucks all air right through the radiator.
I will give you guys an update after it is mounted in permanant.
Thanks again.
-Ed
brewchief
Serpentine belt setup requires a reverse rotation fan, is your fan spinning in the correct direction?
edit nevermind I saw the upgraded highflow pump line and thought you had switched to a serpentine setup.
