If you've got an engine that has relatively low mileage and/or low usage, but uses more oil than it should, I would not hesitate to run a can of oil additive or two.
At least one during each oil change could make all the difference.
You may not remember the story I've told of mine when I bought it. It had roughly 60k miles on it and used a quart of oil every 500 miles or so. Burned it and leaked it very consistently. Also made a lot of noise from the lifters.
After several cans of the thin (solvent based?) additives and a couple of regular oil changes and that went up to 1500 miles, less noise and fewer leaks.
After the third oil change (this was a daily driver at the time), and for the rest of it's life up until I sold the engine with 175k miles on the clock, it used less than a quart of oil between changes (5000 miles originally, down to about 3000 miles with less driving) and didn't make a peep.
Regarding the noise though, some little minor ticking did come back at around 90k, so I just changed the lifters after that.
But the bottom line for me was that, even after the previous owners rode it hard and put it away wet on a regular basis, some good ol' snake-oil therapy worked wonders.
Now, if you've got 200k on the odo, then all bets are off... %)
