Covering rust spots
67halfcab
Michigan
[quote author=Wzbell link=board=5;threadid=12555;start=0#93634 date=1040594493]<br>What the best thing or way to cover about 1/2 dollar size rust holes in the bed? <br>[/quote]<br><br>Your Bronco has Rust? ;D I've never seen a Bronco with rust before. (my 71' before I sold her)<br>
<br><br><br>You can cut around the hole making it a bit bigger and weld in a new piece of metal which would probably be your best bet for long term.<br><br>You can also get some patch material and putty from Por which would be easier if you don't have access to a welder, I haven't use the putty from Por but it appears to be pretty good and if it is as good as their paint you can't go wrong. There web site is Por15
MI-Bronco
JB Weld a peice of patch metal 18 gauge. Or, use a couple of large washers and clamp together (I would still JB Weld them). But best way is to tack weld some patch metal in. I don't recommend the bondo path, it will probably fall out on the first trail.
