Coyote Broncos in AZ
chuck1022
I have always wondered how they run in the 115deg heat of AZ. It really seems to fill every square inch of the engine bay. Just wondered what ppls experiences are in the heat of az
toddz69
I have seen 1-2 in the Phoenix area (including 1 sitting in Driven 4x4's shop a number of months ago). The trucks I saw probably aren't the types that will get driven much in the hot summer months though. Only us old desert rats with worn-out pushrod engines do dumb stuff like that :).
Todd Z.
jckkys
I don't believe the coyote engine is a good choice for any truck. It's a car engine. Any small block is going to test the EB cooling system at 115 degrees. The OHC engines are very wide and leave little room for air to move through the engine compartment. Narrower push rod engines already have that problem. What's the point in using a Coyote? Bragging rights? High speeds are foolish and EBs are a ridiculous choice for drag racing.
MonsterBIlly
There is a guy in North Phx who runs a custom shop. He has a baby blue rig with a coyote. He has over 4k miles in it this year alone. Didnt say he had any problems with it at all. I dint remember his name, met him at Goodguys
C
chuck1022
I just always wondered about cooling......the coyotes seem amazing....but I dont know if the juice is worth the squeeze.
MonsterBIlly
I dont think it is. Similar to the 4770w trans swat. I completed it. I do like it, but not worth the trouble or the money.
I am going to build a 408 or 427 stroker rather than a coyote. Less hassle, less money and more power.
C
chuck1022
I dont really need crazy hp in a Bronco....mustang might be different.
Im leaning towards a Explorer swap...AX15...and Atlas ....although Dana 20 has not caused me to second guess it
Speedrdr
Legend in my own mind
Paris, MS
Got to agree to a point. Had a 72 that I swapped a race prepped 302 in (after I spun the crank in the mains on a 200 I-6) that would run 85 in less than an 1/8 mile. Was the power fun?? Absolutely. Was it necessary? Heck no. Did it scare the crap out of me trying to stop it? Without a doubt. Would I do it again? In the process now on a 77 that I'm restoring.
It all comes down to what we want, not what is needed or what makes sense. That's why we do what we do...at least in my opinion. Lol
Randy
Keep in mind that the Coyote is a more efficient engine. More of the energy is going into the crankshaft for the fuel burned. So that leaves less energy that needs to be rejected by the cooling system. That is for the same 100HP load, the coyote will burn less fuel and have less waste heat.
The other side of the coin is you now have a lot more HP potential that needs cooling. If you are using the HP, you need the cooling for the HP. So where a Coyote in an F150 can tow a loaded trailer up a hill at full speed in the summer with the A/C on, you are not going to do that in a Bronco since you just can't put that much cooling into a Bronco.
jckkys
You'll notice Ford doesn't put Coyotes in F150s or any other trucks. Why? The same can be said of the new Shelby GT350 voodoo engine.
C
chuck1022
Randy
I really need to make more money .....I was just looking at the 2.3 Ecoboost 4cyl and it produced a ton of torque and power..........310ft lbs and 270 hp....
I know the puritans would revolt because it is not a V8...but the power that little motor makes is amazing
and the torque comes on at like 50 RPM
73azbronco
how big is that ecoboost though, with turbos and all, would it fit? If it would it actually makes more sense than the cyote as long as you use the 6 or 8 speed tranny.
73azbronco
I was wondering size, fitment, with all those turbos and things hanging off the sides.
