Well there ya go. I should have asked you this before obviously.
I just mentioned that characteristic in my last post, but can you explain the probably obvious please?
Is it the torque multiplication thing working against things like the case and bearings and such?
thanks
Naw, it's more simple than that. The strength of a transmission is based on a bunch of things, but if you put them in order of importance...it goes something like this:
1. center distance
2. case length
3. gear size
4. tooth contact area
5. tooth material
6. case material
7. shaft diameter
8. a bunch of other things...
At the end of the day, the strength comes from the ability to keep the gears in mesh, (bending strength of the shafts) and the amount of load seen by the individual tooth. Physically smaller gears see a LOT more load than big ones. You can argue that the load on the small gear is exactly the same at the root of the tooth...but large gears distribute that load over...a larger area.
So the strongest transmission you can make would be a 1:1 transmission where the input gear is the same diameter as the countershaft gear. As you increase ratio...the input gear gets smaller, and the countershaft gets larger. If you look at at close ratio toploader, the input gear is almost the same diameter as the countershaft gear. If you look at a NP435, the input gear is tiny compared to the countershaft gear. In order to get a lot of gear reduction, the countershaft must turn a lot slower than the main shaft. So in order to get the main shaft back up to speed, you end up with a relatively large 3rd gear on the countershaft cluster, and a tiny little 3rd gear on the mainshaft.
The NP435 (T18, T19, SM465, SM420, NV4500, and Clark is strong because it has such a huge center distance in a very compact case.)
This is also why the Mustang T5 always breaks in 3rd gear. It has like a 3.27 first, so they launch just fine. Second gear is actually OK, because both gears are about the same size. and close to the support bearing. But when you get to third...you have a big gear spinning a small gear, out where the shaft has the least support. As the shafts push each other apart, the load gets distributed to the top of the tooth, and that little bitty third gear can't take it. They literally flex themselves into oblivion. (It's also why the low ratio Turbo Coupe T5 can't hang with a V8)
The TKO has 3.27 inch (83mm) center distance, but is not as durable as the 3.03 toploader. That's because the TKO has a puny 5th gear integrated into the output shaft. It can't handle sustained torque at rpm in 5th gear. So it actually wears out instead of breaking.
The AX-15 is an 85mm center distance, but has high gear reduction like 3.8.
To make the strongest transmission in the same package...you actually benefit by adding overdrive ratios. So you can get a 2.95 first, and a .50 overdrive in the T56 and all of the gears are pretty much normal sized.
The NP203 range box is a short case, 1.96 ratio, big center distance 2 speed transmission. Try to break one of those...
Hope that helps.
