coyote to 4r70w?
daves bronco
Bonney lake WA
I have decided to start the process of swapping out engines to the new 5.0 coyote, Im going to use a 4r70w auto. (lots of stop and go traffic around here)my question is do i need to look for a certain year donor vehicle. i have found a used one from a 03 pickup with 60,000 for only 350. Am i correct in thinking this trans will bolt up to the new 5.0 motor.
thanks.
Kyle.malone
Norman, OK
thanks.
Ive researched quite a bit on this subject. You need the 4r70w from a mod motor or v6. The bellhousing will bolt up. I have a 4r70w from a 5.0 and it will not bolt up directly behind the coyote. You will still need an adaptor.
bax
Old Member
thanks.
Yes you need the Mod motor bolt pattern. For the new 5.0 (Coyote)
Just like Kyle said.
Now I don't know what state your in but I have a good 4r70w 4x4 trans from a 5.4 at the house. I got a hundred bucks in it if you want it.
