coyote with 4R70W transfer case options
nsdq3
First of all, SORRY! I know this has probably been asked 100 times. I searched for an hour and only found D20 and atlas options.
I thought I wanted to go 6R80, but the cost is prohibitive and again, only D20 and atlas options.
Looking hard at the 4R70W, both from the gear ratio and cost perspective. Also, the NP205 seems to fit all my needs as it is stronger than the D20, but not a straight rockcrawler case like the atlas. So if I find a modular motor 4R70W will the NP205 bolt up or will an adapter be needed. I can't seem to find much info on this combination.
I am building the truck to handle well on the road, be drivable (even on long distance) and be able to do mild trail work, be fun in the snow, etc.
So the starting point. I have a 2014 F-150 motor that I got for a great price. My D20 would need rebuilt to be usable. I don't currently have a transmission.
I know the motor is rated at 360ish. But with headers + full exhaust, intake and a tune it just pick up 25-30. I am setting up the suspension with front and rear anti-roll bars and a well performing street suspension + good brakes and all the other fun stuff.
Axle gear ratios are open ended at this point. Will put in whatever makes the most sense given the tranny and transfer case. Plan on doing 35's on 17's.
N
nsdq3
Also, just a tag on. What older transfer cases offer "shift on the fly". I have gotten spoiled being able to shift into 4wd at 50+ MPH as the traction situation dictates.
I know these are probably juvenile questions to you guys that have been dealing with this stuff for decades, but this is my first venture into combining new with old.
A big thanks in advance to steering a bronco newbie in the right direction
sykanr0ng
Due to the need to fit between the frame rails and have a driver side front output there are only three choices for a transfer case; the Dana 20, the Atlas or the NP205.
What older transfer cases offer "shift on the fly" at 50+ MPH?
None.
If the front hubs are locked in, shift in and out of 4WD at any speed (in a straight line without tire spin) with any of the transfer case options. The hubs will be your limiting factor, not the transfer case. But without the hubs locked in there is no point in pulling the transfer case at speed. The atlas is probably the best option, it has actual syncros for the shift forks.
All (including new stuff) require a stop to get in and out of low range.
The NP205 will bolt tot he modular 4WD 4R70W. The only difference between a small block and a modular transmission is the bellhousing area. There were a few other changes over the years (different tooth count on OSS, adding an input shaft speed sensor, probably more). But those are just the normal yearly changes. Contact your transmission controller supplier on what years will work for you.
Being modular, consider the 4R75W. It was used behind the 5.4 and has a little higher torque capacity and hardened planetary gears. It is the most heavy duty version but only came with the modular motor bellhousing. If you want the ultimate small block 4R70W you put the guts from a 4R75W into the small block case.
73azbronco
FYI, iv'e got a 2013 jeep i tried shifting into 4 hi on a dirt road just cause it said it could, it couldn't.
