CRAZY AWD idea...
MPG_Bronco
Chandler
ok, bare with me...
don't know if anyone know what a NP203 is... but it's chain driven, but has a differential right before the rear yoke, allowing 'full time 4wd' cause it can differentiate the front and rear axles... great for any low traction times, like in rain. but it does have the option to lock the case for the following mods:
4wd hi unlock
4wd hi lock (front and rear = power)
neutral
4wd lo unlock
4wd lo lock
I've seen MANY mods about taking just the 203 reduction box and mating it to a NP205 for a doubler... but I'm thinking about using only the rest of the np203 box...
I wanna clean up the bronco, it's 100% street... might go camping but not much more than that... so bench seat up front, and no floor shifter/s... only column auto shifter. and a bench seat in the back.
I'm thinking of using a 700r4 trans and a NP203 case for 'full time 4wd'... well I want to remove the reduction box and mate it directly to the trans... to make it a 'AWD'... with no low or locking ability. cleaning up cab the floor.
Where can I go to get a custom one off adapter?
I haven't heard back from Advanced Adapters yet... but doubt they will make one
this will be a new DD, and the AWD will help plant the vehicle cause lets face it, high speeds on the short wheel base, it's not that safe. I'm not say'n your isn't... just I don't like that feeling.
I don't care about the mileage loss...
the other option I have is to use the entire NP203 just not install the stick and keep it in 4hi with the center dif unlocked... it's more simple, and lest costly, but just wanted ask about removing the reduction box all together.
Hopstr
Subscribed. I'd like to do the same thing to my street cruiser as long as it's not too loud when it is unlocked.
MPG_Bronco
MPG_Bronco
Chandler
theoretically, when unlocked, the center dif is only being used on turns... other wise it's not used...
i have AWD option in my 99 4runner, and I can hear a difference between 2wd and AWD... it's not loud, but you can hear it... my mud tires are louder.
demesauce
Shaver Lake, CA
This isn't really an AWD system you are talking about, it more like full time 4wd. Just cause you remove the reduction box and mate it directly to the transmission, doesn't change that. But still, an interesting idea
What sort of speeds do you plan on hitting in your Bronco. 80+ mph is pretty unstable in these Broncos, doesn't matter if you are 2wd, 4wd, or "AWD".
Your 99 4runner doesn't offer true 4wd, so they're forced to call it AWD. Same, same... but different
MPG_Bronco
MPG_Bronco
Chandler
This isn't really an AWD system you are talking about. More like full time 4wd. But an interesting idea
your probably right, so below is my understanding of AWD vs Full time 4wd... are you thinking different?
Full time 4WD, also called permanent 4WD, (not to be confused with: part time 4WD ) is a system that powers all four wheels at all times and it can be used full time on all surfaces including pavement. The additional feature of a differential incorporated into the transfer case makes it possible to use 4WD all the time.
2WD is not available (only part time 4WD offers that option). Each tire creates about 25% of the available torque when the ground is level with a uniform surface. Driver has a choice of a "4-high" - 4H (that's your every day setting) and "4-low" - 4L.
Full time 4WD vehicles work very well on-road and are very capable off-road.
All wheel drive (AWD) is almost the same thing as full time 4WD - it is a system that powers all four wheels of a vehicle at all times as well. It can be used full time on all surfaces including pavement like full time 4WD. Difference to full time 4WD is that a "4-low" setting is not available in AWD cars. Due to the lack of "low range", AWD vehicles are much less capable in off-road settings than full time 4WD vehicles, but work perfectly well on-road.
demesauce
Shaver Lake, CA
From my understanding AWD cars also have some sort of "system" to determine where the power goes. Either a computer/sensors, or differentials, or its setup to a certain ration (60% rear, 40% front) As one or more wheels slip the "system" is able to shift the power from the slipping wheel to a non-slipping wheel. But 4WD will give power to the wheels regardless of their traction, or lack there of
73azbronco
Interesting, but are there not a few sensors on wheels and other sensors plus a computer controlling all this?
patterdale
You'd have to pay attention to the gear ratio front to back. These old buggers have the front set to "pull" a bit so different ratios front and back. Not good for dry pavement in "AWD". AWD senses the difference electronically and applies power where needed or drops it to the wheel that loses power.
MPG_Bronco
MPG_Bronco
Chandler
I think you guys are thinking of 'Auto AWD'... I don't want the electronics... so I figured AWD is the right term...
Automatic AWD system is the newest kid on the block. PR agency generated names like "Real Time 4WD", "intelligent AWD" or "active AWD" are hiding the fact that automatic AWD is essentially a sophisticated 2WD system. Automatic AWD is NOT powering all 4 wheels all the time. Only on rare occasions all 4 wheels will be powered very briefly. Since AWD is only engaged on rare occasions, sometimes automatic AWD is falsely called "part time 4WD". Engineers refer to this system as an "on demand system". Since it is based on an existing 2WD steup, it is also referred to as a "hang on" solution.
Here is how they work: Under normal conditions one axle gets 100% of the torque - meaning you are driving in 2WD. During traction loss at the driven axle (could be front or rear) a fully automatic system (hydraulic, mechanical or electronic) makes some of the torque to the axle with traction available. This means you have to lose traction in 2WD on your driven axle first and then the other axle will be added and try to keep the car moving and stable. Once the primary driven axle regains traction and both axles rotate at the same speed again, the system reverts back to 2WD. So, for a brief moment you had AWD.
Automatic AWD is much less capable in off-road settings than full time AWD systems and inferior to full time 4WD. In fact, automatic AWD is almost useless beyond pavement. However, automatic AWD is becoming more and more sophisticated and offers pretty much everything consumers expect for everyday (pavement) driving.
Good call on watching the ratios... everything would have to be as even as possible... otherwise it will use the center dif just going straight.
don't get me wrong, it's not meant to be a 'corner' hugging machine... just something a little better when I punch it on a right turn the tail won't cut loose cause now the front is pulling too... that's the end goal.
Nothing Special
4WD vs AWD is sort of a distinction without a difference. If you have 4 wheels, driving all of them means you have 4 wheel drive. And in order to drive 4 wheels you need to drive all of them.
That said, it's often used as an artificial distinction between truck systems and car systems. Since trucks usually have a low range and cars don't that's sort of a difference. And since cars often have electronic controls that make "AWD" systems work more smoothly that's sort of a difference. But in reality the difference is whatever the person using the two terms means.
Yeller
Rogers County Oklahoma
If using a 700r4 install a awd tcase out of a Tahoe, bolts up and does exactly what you are proposing and does not have low range. They also used np242 tcases behind that trans has low range but can be set to awd and leave the shifter off.
Ranchtruck
Or go all Ford and use the awd case out of a 5.0l explorer/mountaineer. It's actually a nice AWD unit, planetary center diff which gives it some rear bias to the torque distribution and a viscous limited slip unit to control the differential. No electrics, bolts straight to the ford trans that bolts straight to the ford engine. And it weighs a heck of a lot less than the NP203 diff and chaincase would. Use an AOD instead of the 700r4, or a 4r70w if a little electrics doesn't bother you.
OX1
Sounds like the best idea to me. That full 203 setup is really long and heavy.
MPG_Bronco
MPG_Bronco
Chandler
I guess I should be a little more honest... it might be chevy BB swap... :eek:... long story, dont want to derail this topic though...
I could do tahoe... except I need sensors in the axles... that won't work for me.
what years? do you know the transfer case name/model? I'm interested in more info... would be much easier... but I'm not wanting any 'electronic' AWD setup.
i have nothing against ford or stay'n only ford... but in the end it's more important to use what works together. I know ford offered NP203 in some of their 74-79 full size... so it's kinda ford.
thanks everyone for the inputs it's a lot to think about as this plan pans out...
Laxdad32
Fort Morgan, CO
Here is the tag on the AWD tcase. Second picture is just for a quick size reference, a taillight from a 98 explorer was all I had close by.
OK, Ill stir the pot a little as well.
Most modern AWD/full time 4WD systems today are little more than glorified part time 4WD. The rear gets a direct drive, some computer controls a clutch to deliver power to the front. At highway cruise it leaves the clutch off and you are just 2WD. When it sees slippage or even just a heavy stab of the throttle at low speeds, energize the clutch.
The classic AWD systems use a center differential. Most will need a little more than just that. Take the NP203 and don't have lock. Loose traction on just one tire, open diff feeding open diff will get you insane wheel speed. You can be more stuck with that than just a normal 2WD in a mall parking lot. Remember the old 70's Jeep Quadratrac? There was an emergency knob in the glovebox to force the center diff locked. And that center diff was a limited slip unit as well.
Now back to a crazy 700R4 AWD combo. There are kits to put 700R4 into Rangers with the 4.0 V6. Look for the back half of that kit. Probably the 25 spline 5-bolt Ranger transfer case. Now go find an AWD Aerostar. That had the last true center diff transfer case I know about. High range only. It was behind the same 4-speed auto as the Ranger with the 4.0 engine. The Aerostar AWD transfer case is high range only. Now for the one spinning wheel stuck, well the aerostar had a simply computer that locked the center diff as needed. I'm going to bet you can put in an emergency pushbutton to allow you to manually do the same thing.
No, I have never done this. But using parts that typically interchange, it may be possible. More research should be done before doing any investing in parts.
Yeller
There's no sensors for the awd part on the Tahoe, just has a differential in the case.
And no worries I'm used to stirring the pot I'm the LS guy:-X
EFI Guy
TheEFIguy@gmail
BFE
I was going to say the 203 will bolt to a 4r70w, or there's the AWD Explorer Tcase if it will fit between the rails. But then...
More specialty work needs to be done for many of the modern cases. The newer aluminum ones would be nicer than the 203 in many ways, but most of them are too wide to fit between the frame rails of an EB.
So while that's not impossible to get around, it's one more layer of stuff to think about and do.
