Custom PS hoses?
Hazegray
Problem I run into with hoses made at the local shop is crimp on ends means you need to have the routiing and the exact, I mean exact clocking of the fitting (any fitting that isn't straight). If the end is crimped on you cant rotate that hose to make it line up. :(
Hoses that you build in your shop and can repair on tbe trail allow you to rotate your fitting ends for proper hose routing.
Just a heads up.
you are right, but you do have a little wiggle room on the fitting itself. I used some old 3/8" fuel line clamped on the fittings as a mockup when I took them in.
I used Aeroquip FC300 hose and fittings from Speedway Motors.
Beautiful setup Digger! Love the use of hard lines across the frame. Nice bending and routing.
We sell the adapters that are needed in most cases DC Gearhead. Available in many places, but if you happen to be buying something from us you can add them in for little to no shipping penalty.
We have hose kits as well, which is what I've used on a couple of Explorer front drive installs. Works out very clean and tidy.
I've used both of these kits at various times:
https://www.wildhorses4x4.com/product/Ram_Hose_Kit/broncohydraulicsteeringparts
Depends on how much hose or what fittings I want.
Same idea some were referring to getting from a hydraulic supplier if you happen to have one locally that stocks different stuff.
