Hey guys, I need to build extended radius arms for my Full Width SASed '90 Ranger. Once I get them made, a second set will be fabricated for my '66 Bronco. Call the Ranger a test run.
I want them adjustable and with the 3 Heims per side, there will be no side tension on the C-Bushings. Here's a quick sketch I drew:
The Top link will be the support, while the bottom will be used for adjusting caster (Tiny bit) and eliminating axle wrap. Is there anything I'm not seeing or accounting for?
Also, what length should I shoot for? I am using stock '79 Bronco arms now, should I go longer or is this fine?
