D 44 Help, No 4 wheel drive
carter2772
Camano Island, Wa
1974 stock d44 front, open....
My eb's 4 wheel drive is not working.... I know its got to be something simple, so before i tear it all apart, i am looking for some advise...
So the 4 wheel worked before i took it all apart this last summer. Prior to going to sob, i decided to redo all the seals u joints and bearings in the d44. There was nothing mechanicly wrong with it prior to taking it apart, other than a leaky seal, i just wanted to redo all those parts...
Here is what i know.
- No extra parts from when we put it back together
- Hubs are locking and working, with hubs locked i can not turn either axle by hand
-t case is working in all gears, 4h, n, 4l, 2h...
Again, all the parts went back in, everything fit, no extra parts.
My next plan of attack is to pull the diff cover and inspect, but seeing if there is something i am missing....
Help, i want to play this saturday at Walker...
rsharpnm
Las Cruces
Hmmm... to be clear:
When you jack up a wheel and lock the hub, and put the T-case in 2wd, does the wheel and the driveshaft turn? When you put the T-case in 4wd, with the hub locked, does the wheel turn? And when you put the T-case in 4wd with the hub UNlocked, does the front driveshaft turn?
Sure sounds like a hub problem, but you say they aren't. Stymied...
Viperwolf1
electron whisperer
When you turn the front driveshaft (hubs unlocked, tcase in N) do one or both of the front axles turn? If one side turns, lock that hub and try again. The other side should now turn. If it doesn't that axle is not being driven by the diff (broken axle).
carter2772
carter2772
Camano Island, Wa
Not quite sure what you are getting at, Viper, with unlocked hubs and in N, why would any of the other 2 parts turn while turning the 3rd piece, if the are all unlocked or in N.... But i will go try..
I will go do what both you guys mentioned and report back.... Thanks for the replies...
Viperwolf1
electron whisperer
At least 2 of the 3 will turn unless something is broke. They should be connected at the gear teeth.
OX1
Or that hub is not locking. I'd put money on that
as it's the easiest thing to have not working right
after you reinstalled everything with it all working before
you started.
Viperwolf1
electron whisperer
you started.
Right, but he says the hubs are working. And my method checks the axles without the hubs coming into play.
carter2772
carter2772
Camano Island, Wa
Viper, I used you method and found that the passenger side hub was not locking... The gear that ingauges the axle to the hub when the hub is turned to lock was put in backwards. There is teeth only on one side of that gear, on the inside, and it was in with the teeth to the outside...
Go, go, 4wd! Thanks for the quick replies fellas!
rsharpnm
Las Cruces
Hoo-ray! Easy fix, you have brought balance to the Force, and the crowd goes wild! Good job!
