D44 Assembly
And so will the bearing adjustments.
You'll need one of these if you don't have one: https://www.wildhorses4x4.com/product/Wheel_Bearing_Nut_Socket/More_Tools and every Bronco owner should have one if they do even a tiny bit of their own maintenance.
Unlike modern unit-bearings, old-school front wheel bearings are a service item, about every 25k miles or so. And a properly maintained they will last the life of the vehicle. Also unlike modern unit bearings.
You should have a Chilton's and/or Hayne's service manual too, if you don't already. Or a Ford set is even better, but the others are very workable for most work.
When you're ready to install the bearings let us know and we can run down the details.
okie4570
NW OK
Give me a shout if you get stuck on the front end, rebuilt several of them, all on a lift though fortunately lol.
Okie69
Okie69
I’m gonna end up having you to thank for the whole bronco!
Okie69
Okie69
Hey Paul, which Chilton / Hayne’s manual should I be looking for? I assume one for the bronco itself would be handy. But since I’ve got pieces and parts from different vehicles?
I have a feeling you’re going to say something like get one for all of the trucks you have pieces of on your bronco.
Good point. And for that matter I suppose you should have a "73 to '91 Chevy/GMC Truck and Blazer" book too!
But I'm betting they're extremely close, if not exactly the same when it comes to bearing adjustment.
Just in case though, the latest Chilton's that covers "66-'96 Broncos/F150's" would be your go-to book. Unfortunately the one I have leaves out one of the most important parts for me. The wiring diagrams! I can't believe that still print service manuals without wiring diagrams.
I usually consult the earlier "66 to '77 Bronco" book because it's less full of other stuff. And has wiring diagrams. But some members here say they prefer the later one with all the other trucks included. So you may have to decide.
The early carries a number of #6701 and the later is volume #7140 in case that helps the search.
For Hayne's it's much the same thing. The current one like we sell (https://www.wildhorses4x4.com/product/Haynes_Repair_Manual/Bronco_Books) I call the "blue" version (I forget the volume number at the moment) but the one I like even better if you can find it is the older "brown" version #788.
Here again, the blue one is more updated and very nice, but I like the old one because it has better wiring diagrams.
Any of them are extremely helpful in a pinch.
Okie69
Okie69
Resurrecting my old thread here since I’ve come up with new questions.
(This is all I reference to the ends, not doing anything to the center section at this time)
I want to make sure I’ve got everything I’m going to need so I’m not waiting on anything when it’s time for assembly. It looks like maybe there are some differences in seals or slingers on the HP D44s? There was an option to add slingers on the axles I purchased from WHs but I didn’t add them based on some of the stuff I read.
List of what I have at the moment.
-New axle shafts coming EB width.
-inner and outer bearings and races
-Inner wheel seal
-inner spindle bearing
-v seal (i think I might be doubling up here but it was cheap)
-bearing adjusting and lock nuts
-tapered sleeves for f150 knuckles
-new 19 spline locking hubs
Let me know what I’ve missed! Trying to get the assembly and install to go as smoothly as possible
jamesroney
Fremont, CA
OK, I just re-read the entire thread because you confused me.
Your pictures show a cast wedge Dana 44 from a 78-79 Bronco. ( yes, it is the same housing as the 78-79 F150.)
1978 was a strange year for Ford, and the HP44. The tube diameter got larger, (from 2-3/4 to 3 inch) thinner, and the inner housing seal changed. The Dana 44 inner seal from earlier years is smaller on the OD.
Also, the LH inner axle shaft for your build is NOT correct for EB width. I can see from the pics that someone narrowed ONE SIDE only on your housing. That means that your housing 5/8 inch LONGER on the driver's side than an EB. So you need an EB length right axle, and an F150 length left axle. The F150 uses a 5-760x (old number 5-297x) axle shaft u-joint, which has bigger cups and trunnion than the 5-260x early bronco joint.
So the axle you need is the F150 axle on the left, and a 5-760x jointed early bronco length shaft on the right. Many of the providers sell this combination. When you are done, your WMS will be 5/8 wider than EB.
The axle shaft slinger is another issue. It needs to be there for the dust boot for the stub shaft thrust washer. The 76-79 D44 uses the same dust boot and thrust washer. The boot will not fit the axle stub if the slinger is not there. I don't know which stubs you are using. If you are using the factory 19 spline stubs, then they use the slinger and dust boot. The only Bronco stubs that I know of that don't use the slinger are the early (71) D44 stubs that have a pressed in seal.
Okie69
Okie69
Thanks for the reply, and sorry if I was confusing. I’m trying to keep it straight in my head too!
How can you tell if the driver was shortened or not? I’ve been trying to figure out if it was or not for awhile now.
Also how can you tell it’s a ‘78 ‘79 bronco and not an F-150? Just for my knowledge.
I have the driver axle shaft that came with the housing. I don’t have the passenger which is why I’m buying new ones. I’m going to measure the driver shaft and see which length it is.
Is this the larger seal you’re talking about?
https://www.wildhorses4x4.com/produ...na4478-79F-150Bronco/fullsizebroncofrontaxles
Okie69
Okie69
So yeah the driver axle shaft that I have for this front seems to be the full size. What I found says 18 29/32 for full size and 18 5/16 and the center of the yoke is at right under 19”
jamesroney
Fremont, CA
So you have the LH axle that you need. You will also notice that it has the Heavy duty (1-3/16) u-joint caps. It also has the "slinger" and I can see the dust boot. It will have a 19 spline outer stub. If your housing was narrowed 6 inches, then the passenger axle will need to have the same big joint, but needs to be EB length. You can use that same tape measure and shove it into the right tube, hook the end of the tape to the inner gear on your trac-lok and measure to the knuckle. Then do some math and you can figure out your ideal axle length. If it was done right, it will be EB length.
I noticed that your housing was only cut on one side by comparing the weld quality of the left tube to the right tube. The short side looks a lot better. Plus, it is REALLY hard to cut 5/8 inch out of a cast wedge housing. The axle tube end protrudes into the forging by an inch, so if you cut it off...then you lose a lot more than 5/8 inch. Otherwise, you would have to carefully grind the weld, and then separate the two pieces, then cut if off, then press it back, and then weld it. Most garage shops don't do that. It's the reason why I like welded wedge housings from a 76-77.
The 78-79 Bronco HP44 is just a name. It is only to differentiate it from "the other one." There are 6 dana 44 variations that end up in an Early Bronco, so you need some shorthand to ID them. I know them as:
1. 71-75 Early Bronco D44 Drum Brake housing named "Early Bronco"
2. 76-77 Early Bronco D44 Disc Housing "Disc Brake Bronco"
3. 78-79 Bronco (Cast wedges, also 78 F100, 78 F150, 79 F100, 79 F150) All the same, just named "big Bronco"
4. 76-77 F100/F150 D44 HP Disc Brake, welded wedge. Popular SAS swap for GM. "welded wedge"
5. 77-79 F250 D44 HP. These are leaf spring with a pad cast in the housing. Factory 8 lug.
6. 71-75 F100 D44 HP Drum Brake. welded wedge. Beware of older 66-70 closed knuckle versions.
jamesroney
Fremont, CA
Keep in mind that the 76-77 disc brake hoses use 7/16-20 fittings on 3/16 tube. The big bronco uses 3/8-24 fittings, and a ridiculous 1 piece right hose tube thing.
I like the 76-77 hoses, but you will need a tube kit for the 76-77. If you get the tube kit for the 71-75 with GM disc brakes, it comes with 3/8-24 fittings.
You can choose to go “standard” with all 3/8 fittings, or you can go “the other standard” with oddball Ford fittings. The last 10 I’ve done, I just use all Ford parts, and bought new tube kits. Then everything is “1976 Ford Bronco”
Okie69
Okie69
I appreciate you taking the time to talk me through it sir. As I was reading your response I was thinking “this guys a wizard how does he know the u joint cap size?!” ….then I looked at the picture I sent haha
Okie69
Okie69
Now that I’ve got my electrical issues figured out it’s time to finally move on to the axle swap. Here goes nothing.
Chief Master Sergeant
Retired U.S. Air Force
I use my wheel dollies for the same thing, but put jack stands on the dollies. Makes it much easier to get out from under the Bronco using those dollies. Just pulled my stock Dana 44 yesterday; waiting on T-Rex Arms. Good luck with the swap. Lots of great help on here if you need it.
Okie69
Okie69
Oh yeah jackstands would’ve been a good idea.
Hey I’ve got T-Rex arms on the way too! Figure I’d might as well while I’ve got everything apart.
Okie69
Okie69
Great idea!;D
We do have the hoses too, depending on what type of hose you want.
If you just want rubber, a '76 TWO-WHEEL drive hose works. If you want braided then we have those on the shelf.
Paul Sir
I’m emailing back and forth with WH sales and I’m trying to make sure we’ve got it right. Up here you said I could use a 76 two wheel drive hose to work with this new axle. They’re telling me I need part#3185 the 76/77 caliper hose. Is that right?
Hi Okie.
First let's be 100% clear on what you're working with.
From your earlier posts you are using a later model high-pinion 44 in your early Bronco. Correct?
This is a '69 as in your username?
The most important aspect now is, what hard lines are you using with this axle assembly? Are they '66 to '75, '76 and '77, or custom by the installer?
If custom by the installer, you need to verify which size they are out at the caliper ends.
If you have a '76 or a '77 Bronco, OR have a swapped-in Dana 44 from a '76 or a '77 including the stock metal brake line tubes from that year, OR the hard tubes were sourced from a '76 or '77 Bronco to fit the new cut-down axle, then yes you need the WH #3185 because those are the "stock" replacements for a '76 or '77 with the larger fittings. Available in both rubber and braided stainless. Your choice.
If you have a D44 from any other year that you have swapped in that still has that year's steel brake tubes on it, you need the #3188 available in braided stainless only.
Since you have a swapped-in HP44 from a full-size, then you might be using custom bent brake lines from the installer. They will need to verify what they used. Probably 3/16" ends, but no guarantee of that until they tell you.
To fill in the blanks, the brake tube fittings on the axles of EB's were different between the smaller '66-'75 fittings and the larger '76 and '77 fittings, so it depends on what exactly you are working with.
We sell the #3188 (https://www.wildhorses4x4.com/product/76-79_Caliper_Hose_to_3-16_Inverted_Flare/Bronco_Brake_Hoses) parts for when 3/16" tube fittings are called for, but do not offer a rubber line. That's where the previous recommendation for a '76 2wd F100/150 came into play. Only if you want rubber hoses.
The difference is the 3/16" inverted flare fitting out where the caliper hose meets the metal lines on the axle. We just don't offer them in rubber for whatever reason, hence the added info that might be confusing things. Sorry if that's the case.
As probably mentioned before, the braided is more durable and even with just normal use will generally outlast the rubber ones by a large margin. If you're looking for more stock looking, or just wanting rubber for whatever reason (it is less expensive usually), then you'd have to source the using the earlier info.
If you want braided then we can supply it, but you need to know for sure what the fitting size on your (probably new?) tubing is.
Hope that helps.
Okie69
Okie69
Yes sir. The 69 with the later model hp d44. I need all the lines from the flex line down to the axle (2.5” lift) all the way out to the calipers. Does that make it easier? 😂
I’m the installer. The only existing lines I have are the old ones off of the D30 and I’m thinking I’ll just replace them all while I’m here.
