Damn Electrial Gremlins!
Krawln68
Newark, CA
OK, Im stumped. I can start my rig a couple of times before there is no juice to start it. Then if i leave it for an hour, it starts back up again, but every time i start it after that, it progresivly fades till it cant start again. Ive replaced the Alternator, voltage regulator, and the negative cable(the positive is new). The lights turn on bright, the stereo turns on, and even the ARB compressor can cycle no problem...........WTF!
Krawln68
Krawln68
Newark, CA
I drove it monday, and it just died on the way to work, so it cant be the starter, and after its running, it gets its juice from the alternator, so thats why i replaced the alternator.
lars
Been here awhile
NorCal flatlands
Sorta like this
Krawln68
Krawln68
Newark, CA
Good one lars. I dont think its the coil. I can start it and stop it about 4 or 5 times, but it gets weaker with every crank, till all i hear is the solenoid clicking.
TJK74
Newark CA
Hmmm the VR did do the trick either... I would now like Ransil said suspect the Battery especially since you had it sitting for a while since you last ran it. Pull the battery from the 5.0 and see what cha get. I know you have an optima but come to think of it way back when on my :-X Ramcharger I had a battery with a broken/shorted cell that did the same type of crap.
BRONKEN said:
replace the coil ;D I'm sure Trevor has one laying around...
Ken
Hmm I'll have to check... Are you sure I didn't sell that to you already?;D;D;D
I still have an Aux Tank set up waiting for you in my garage ;D
BRONKEN
Morgan Hill, Ca
Also check your ground cable really well. It can start to fail at a bad connection or cut int he cable which sometimes hard to spot.
Ken
Trevor: What is causing the seepage on the tank? I could use a good tank for my dads 73. For some reason they took out the factory tank & replaced it with a steel one with funky brackets.
TJK74
Newark CA
Ken
Well this would go perfect in there ;D
I'll send you and email
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
In the No Start situations, is it not cranking or is cranking and cranking but won't fire up? Because a bad coil will not cause a problem with the starter's cranking.
Krawln68
Krawln68
Newark, CA
Those of you that said battery get a gold star! I threw the battery to my stang in, and no problems. So i went and bought a brand new yellow top.
