Dana 20 Needle Bearings
smdanko
Denver
So I am almost finished with my Borg Warner 5spd conversion and have been told I do not need the needle bearings that are in my Dana 20 for re-insertion to the trans. Has anyone not used the needle bearings with a trans swap?%)
Viperwolf1
electron whisperer
I can't imagine why you would not need them. How does your tranny output shaft mate with the D20?
S
smdanko
Denver
I was able to slide it right into place since it has a gear housing part way up the output shaft and another on the end.
Amac70
ME
you definatly need the bearing in there if you don't your intermedate shaft is going to float and move around. as soon as torque is applied its going to push that shaft out of perfect alignment and things arn't going to be good after that.
Viperwolf1
electron whisperer
You got any pictures of this thing on the end? Are you not using the bronco adapter, input gear and spud shaft? The rear end of the spud shaft goes through the tc input gear and fits inside the rear output shaft with 13 rollers between the two.
S
smdanko
Denver
I will take some pictures. Thank you all for your input and I will put the needle bearings back in.
It will go together without the needle bearings, true.
It will not stay together without the needle bearings.
The bearings are to keep things aligned under load.
You got bad info.
