First off: 1970 Bronco, 302, 3 speed with Hurst on the floor, D20 with Hurst shifter.
I have been unable to determine the true shift pattern for my transfer case since I purchased the truck in May '09. The stock shift knob shows the pattern to be: from the dash - 4L, N, 2H, 4H. I got the case stuck in what should be 4H last year and ViperWolf1 helped me with the method to unstick it. Thanks ViperWolf1...
I was in 4WD for the snow in Colorado Springs and the truck seemed sluggish, so I think my shift pattern is not what the stock shift knob says it is. A quick check in the garage with the truck running, from the dash - two distinct shift points with movement, neutral, two more shift points with movement. Is there something wrong with the transfer case/ Or is the pattern reversed because of the Hurst shifter? This is my DD and I need to know so I don't blow it up.
Thanks in advance..
SevenT
Thanks in advance..
SevenT
