I'm rebuilding my Dana 20 and need some advice.
The speedometer drive gear seems to be seized on the rear output shaft. It's a steel gear. I believe these speedo drive gears are supposed to just slide on and off the output shaft. I don't want to leave it the way it is because I can't adjust the shaft preload properly if the gear won't move. Any suggestions to get the gear moving? I can't put much force to it as that may damage the threads. Will heating it with a propane torch cause any problems?
Viperwolf, do you have any suggestions? You seem to be the Dana 20 man.
