Welcome to Classic Broncos. Now get off of here and go buy a Bronco.
Just kidding
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
My question would be what type of shifter do you have? The shift rail "pills" require the shift rails to move in a certain sequence.
thx for the welcome guys....
there is a single shifter that allows in the furthest aft position 4L, 4h, n, 2h, 2L. there is a bracket off the t case that supports the shifter and it attaches to a horizontal bar that moves the two shift rails....i will lock the hubs in the am and see if 4h works.
i was under the truck and had my buddy shifted it through the 5 positions and everything moves as it should as far as the shift rails are concerned
last night there was a tree down in the road, so i just switched into low range 2L to climb a hill and go around the tree, then when i shifted back into 2h...nothing, fortunately i was only a few miles from home so i drove home in 2l. thx for any insight, rm
