Dana 30 discs
doghows72
So I found a Dana 30 from a jeep Comanche and I'm wondering if I can swap out the disc brakes onto my bronco Dana 30??
Anyone know? Thanks Steve.
No idea. But there are lots of Jeep parts that are definitely NOT compatible, so be cautious and if you don't get a direct answer here, definitely take lots of measurements.
Are the parts nearby where you can go take a look? You know them so if it doesn't work out you could return them?
doghows72
doghows72
I think I found the answer, it NO. The axle under those are 5x4.5 lug pattern so you'd be back to square one trying to find hub bearings etc etc.
I'd love to find a 44 with disc but mine being mostly street mild trail the 30 is fine. I'll probably end up just buying a kit. Seems easier for me no matter which angle I try!! lol
jcasey12
Newbie
You should consider the Chevy conversion. I did that on my D-30 Bronco a few years back and it was pretty easy. And not too expensive if you can find used parts.
doghows72
doghows72
After trying to source used parts and finding all the other pieces, it's cheaper and less time consuming to just buy a kit. Plus I have all new parts as well. I've been researching this for months now, and I actually did the chebby conversion on my 72 but that was fifteen years ago when the used parts were easy to find. Now I can't even find the used parts for less than $300, then another 300-400 for all the bearings seals hoses nuts bolts and time.
It's kit time for me.
Jeep parts, no. Uni-bearing, ball joint knuckles. Completely incompatible. You might be able to use the ring and pinion from that axle and that's about it.
Chevy conversion that has been around for ~25 years works just fine. And is just about the only way to do disk brakes on a D30. The only affordable way anyway.
doghows72
doghows72
Well after a few weeks of deliberation and calculations I ordered my disc brake kit today. I ended up going with horsepower sales off eBay.
After comparing the three local to me bronco shops and the horsepower kit I made them all the same. As far as bearings vs no bearings, braided lines compared to rubber, prop valve vs no prop valve. And after making the kits the same parts wise the horsepower kit came in at $733 with prop valve shipped to my door. Also spoke with Dan at horsepower and he is including fittings for the prop valve just in case, and the mythical washers and bolt for the axle end in case I need them.
He was very a great help asking all about my rig so I'm very confident it will go together without issues.
Thanks to all you guys for the tips and advise, this site and all you guys have saved me and countless others lots of cash by avoiding mistakes.
Two thumbs ups to all of you!!
sneditch
Thanks forposting this @doghows72 - I am in a similar place with the Dana30 and appreciate your legwork and the opportunity to follow the thread. cheers.
