Dana 30 Swap Help Needed Regarding Spinldes
joshnjulie1
Moreno Valley, Ca
I found a great deal to swap out my current Dana 30 for another one. Much cheaper than repalcing what I needed to. I was given the entire front end including the brake parts and spindles. When I lined up my 2 old spindles versus the 2 newer ones I got, one of the spindles seemed off. Seemed a little shorter and did not have the flange ridges (whatever you call them) like the other 3.
Becasue I got all the parts that came with the newer front end, I am assuming everything woudl fit fine but I need some reassurance here. This third odd ball spindle seems either aftermarket or for a different front end/brake system. Below are the pictures I just took so you can see the differences. Any help would be greatly appreciated.
joshnjulie1
joshnjulie1
Moreno Valley, Ca
In the 1st pic, the oddball one is on the left.
In the 2nd pic, the oddball one is on the right.
In the 3rd pic, that is the oddball.
In the 4th pic, that is a common (3 of them) one.
joshnjulie1
joshnjulie1
Moreno Valley, Ca
I am surprised I have not gotten a response from the experts from this one. I am going to bring it to the top and try again. This different spindle scares me.
The same (or as we are finding very similer) spindles were used on different versions of the Dana axle. My quicky thought is you have a spindle that is out of a chevy or Jeep. Someone probably damaged one and got a junkyard one that worked but is slightly different. I know there are difference between disk and drum spindles as the backing plate differes between behind and in front of the spindle.
But as for what spindles you have, which are correct, I don't have any spindles around the house to look at right now. I don't recoganize the differences enough to tell you off the top of my head either. But give it time, someone will have parts and pictures and can update this.
gravelrunner69
ZAP
sorry about that I must be doing something wrong, but if you go to my profile page and go to show all posts, go to the last page and there is three posts that refer to chevy disc conversion I think that will work.
gravelrunner69
ZAP
just reread your post I don't know how I got tunnel visioned that it had anything to do with discs, so what I posted probably has no use in your predicament sorry and good luck
Bullitt94
Marshfield, WI
I think you are going to be O.K. The things you need to look at are where the steps are relative to one another from the end of the spindle in to the back of the flange. In this case, they look pretty even and the diameters look to be the same so you should be in the clear. Key word is "should."
Pa PITT
Stephenville TEXAS
I don,'t remember but I don't like that oddball spindle I've seem it before. I think maybe off some old drum stuff. Or maybe off a dodge front axle. I.d get another spindle too much work to get Everymanthing put together and find that it's an 1/8 inch too short.
I think there will be several that'll disagree with me and say you can use other spindles . But I want them to fit like I know they are supposed to fit.
Someone else will chime in I'm sure
joshnjulie1
joshnjulie1
Moreno Valley, Ca
Going to take them in to a local guru and see what he says. If needed I think I will just pick up what I need to be on the safe side. Not a fan of doing things twice (who is?) so I will wait. Somehting is just not looking right and I dodn't have the knowledge to make that call. Thanks for all the help.
joshnjulie1
joshnjulie1
Moreno Valley, Ca
I forgot to mention that the original 2 that were in the Bronco did not look good once I removed the bearings. Not sure the name of the bearing but it looks like there was damage inside from bad bearings being run for too long. That's why when the newer front end I got came with 2 different looking spinldes I got worried about which one is which.
