Dana 44 disc hub assembly
Just about anywhere. It's a hub-n-rotor for a '76 to '79 Bronco/F150.
The Bronco vendors like us keep them in stock, but since it's a standard replacement item you can find them at just about any well equipped parts store in a pinch.
Some will already be assembled, while others require you to put them together and press in the studs.
Are you looking for a replacement for an already installed disc brake setup, or are you trying to convert your drums to discs?
If the latter, you need more than just the hub and rotor.
sykanr0ng
According to a guy with the user name NumberDummy on a Ford truck forum:
1976/93, the hub and rotor are the same.
The original 1976/79 part number of D6TZ-1102-A .. Hub & Rotor Assy. was replaced by the following:
E1TZ-1102-A > replaced by > E1TZ-1102-C > replaced by > E7TZ-1102-A > replaced by > F3TZ-1102-AA .. Hub & Rotor Assembly-1993.
Originally sold as an assembly only (1976/93), Ford has now replaced the hub & rotor assembly of F3TZ-1102-AA with individual parts. So the hub & rotor are now available separately.
Bill (NumberDummy)/ Retired Ford Parts Manager / Part number research: 1928/2001 trucks & 1928/89 passenger cars.
1963hotrod
1963hotrod
Oroville
Yes it is the 74 dana 44 with disc brakes. I wasn't sure if they were different than the 76, 77 hub assembly. I kind of figured they would be the same. Ford was good about interchange of parts on various years. Thanks guys.
broncodriver99
Glen Allen, VA
Yes it is the 74 dana 44 with disc brakes..
'74 would have come with drum brakes from the factory. Discs weren't available until '76. We need to know if you are running a Ford disc conversion or a Chevy conversion. The rotor may be the same for all I know as I haven't done a Chevy conversion. A picture would help.
sykanr0ng
The hub and rotor are the same whether you do an all Ford disk brake conversion or the Ford+Chevy parts mongrel conversion.
1963hotrod
1963hotrod
Oroville
Here is what I have.The color is not the best.
1963hotrod
1963hotrod
Oroville
You have a set of hubs and rotors in your photos. Why are you looking for another set? Something wrong or worn on the ones you have?
Just for future reference and parts needs. I ordered new wheel bearings and seals. It was pretty rusty and the inner seals were in bad shape. One was leaking and that's why I tore it all apart.The wheel bearings and races were rough. The 44 I am working on is not in the bronco yet. I bought it 2 years ago and wanted to see what shape it was in before installing.I have lots to learn and I am looking forward to doing so. I bought ball joints too, having trouble getting the threaded insert out of the top ball joint on the first one. It wants to booger up the special socket teeth. I stopped and sprayed it with PB Blaster and letting it sit overnight. I hope it comes out tomorrow.
sykanr0ng
Get some Kano Labs Kroil or Aerokroil they are much better penetrating oils than WD40 and you will need that.
For your future reference then, as was pointed out you do have the GM conversion parts on your Dana 44.
It still utilizes the Ford disc rotor and hub, but uses GM-based brake calipers, caliper brackets and hoses. Also Dana spindles from an early seventies GM application.
Note the 6 bolts holding the spindle to the knuckle. That's an indicator that the knuckles are still drum brake Ford. While the other manufacturers stayed with the same setup there, Ford went to a 5-bolt spindle with a larger flange and register opening.
On a side noted, since yours were already installed and (supposedly) working, the knuckles have already been ground for clearance for the GM based brake calipers. But it would not hurt to verify the clearance when reassembling things. You need to see some good daylight between the caliper body and the knuckle. If you have 1/8" all the way around, you should be good. From memory at least. If you ever want to double-check, here are the instructions for our kit that Scott linked to above: http://cdn.wildhorses4x4.com/downloads/WH/3002-3003 2-1-11.pdf
So when you go to ask for hubs and rotors, ask for '76 Bronco. If looking for replacement calipers and brake pads, that's a different story. Maybe just ask for '74 K10 or something like that. The actual part numbers for the pads (a very common number at the auto parts sources) have been posted here many times too. I just don't remember what the number was.
1963hotrod
1963hotrod
Oroville
Thanks Paul, Great to know just what I have. So much knowledge on this site. I think you can get any Bronco related info you need. Thank you to all.
Glad to help. I forgot to add too, that the locking hub mechanism (aka lockouts, free-running hubs, etc) are all basically the same, whether you have a Ford, Chevy or certain models of Dodge products.
If you look at the aftermarket lockouts such as those from Warn, they use the same part number to fit all '66 to '91 GM, to '96 Ford and most Dodge to about '93. Light duty trucks and utility vehicles anyway.
There were actually some differences between the GM truck axles that they were patterned after and the Ford, but they all fit and function. You just have to leave the small snap-ring off of the axle shaft on 90% of the Ford installs.
That's mostly unneeded information at this point, but it will probably come up for you at some point.
1963hotrod
1963hotrod
Oroville
I did buy a set of Warn hubs while I had it apart. It had two different hubs, They were pretty crusty. My problem now is the threaded insert in the ball joint. Hit it with the impact and all it did was strip the 4 teeth on the socket. Pondering on that. I need a new socket, it didn't hold up very long. I filed it and the metal is soft. Probably China made.
Is it just there by itself, or is the ball-joint still pressing up into it? Sounds like the knuckle is off, but I wanted to make sure. They just won't let go sometimes if the knuckle and ball-joint is still installed.
Good luck.
And for the next one, anti-seize is your friend.;D
1963hotrod
1963hotrod
Oroville
Good luck.
I bought a ball joint press and man, the ball joint does not want to move. I did manage to get it to move some and then took a break from it. I will try again soon, lubed it up some more. It popped a piece out of the bottom of the ball joint from the pressure that was applied to the stud. I think I may be missing something.
Wondering if you mean that the knuckle and ball-joints are still attached to the axle's steering yoke where the sleeve is?
If so, you need to remove the entire knuckle, along with it's ball-joints still pressed in. The sleeve does not come out first. The knuckle comes out, then the sleeve.
So if you have not already, remove the lower nut as well, and let the knuckle assembly drop out the bottom. Hopefully not on a toe or three!
Once the assembly is removed, the ball-joints can be pressed out of the knuckle. Once they're out of the yoke, the sleeve can be threaded out.
In theory anyway...
Since the sleeves have been soaking in penetrating oil all this time, with luck they'll come right out.
