englewoodcowboy
Lick Creek Restorations
- Jul 25, 2010
- 4,200
I have decided to run 4:56 gears on my bronco (ADO with 33" BFG's) and have been looking at ring/pinion sets. I originally was going to put true trans front and rear but knowing my bronco will only see very light off road like a two track forrest road etc. and the expense of a locker differential I am thinking going with a true trac in the rear and leaving the front open but this leads to my question, I see the diffs are specified for certain gear ratios, is this the same for the open carrier that is in there now? If so, is there a preferred carrier to go with? I am trying to keep somewhat of a budget and be realistic with its intended use when it is done. Any ideas/tips/suggestions?
