Dana 44 Locker Install - Remove Axle?
tcjones76
Tyngsboro, Ma
OK, I want to put the locker in the front before the run Memorial Day. The question is, should I take the time to remove the complete axle, to make the carrier change easier.
Recommendations?
tcj.
Steve
Grand Junction, CO
While it's easier to work on out of the vehicle IMO it's not worth the time and effort involved pulling and reinstalling the axle just to change gears or install a locker.
av bronco
Palmdale CA
just pull the tires and put it on jackstands, then start having fun, especially putting the carrier back in.;D
ken75ranger
Troy, NY
Just jack it up high enough that it's comfortable to work on. I raised mine up to eye level when sitting. Easy to crawl under too.
What kind of locker are you putting in?
tcjones76
tcjones76
Tyngsboro, Ma
I picked up a used Detroit Locker that will let me run my stock 3:50s until the 33's wear out and I step up to 35's.
I ground the bearings that I had pulled off the locker for setup bearings and I have a shop down the road that will press the new ones on. I have to pressure wash the faulk-out of the undercarriage before I get into it.
I figure I will go for it under the truck, and if I can't get it right, I'll move the jack stands to the frame, and yank the axle. Of course, then I could put in 3.5" coils, yeah and a track bar drop bracket, yeah and F-250 shock towers...
... stop it, fool, just change the carrier!!:cool:
ken75ranger
Troy, NY
Sounds like you have it well in hand. :cool: You can't clean it enough before you get under there. A good size pipe wrench is handy for holding the yoke while you tighten the pinion nut. Wedge it against the radius arm.
70_Steve
Old Guy
I made a tool from a short piece of flat bar and 18" of 1" pipe. Drilled two holes in the flat bar the same spacing as the u-bolt at the yoke. Worked really great.
tcjones76
tcjones76
Tyngsboro, Ma
Hey Ken, been a long time...
If I am just swapping the carrier, using the same ring and pinion, shouldn't the pinion depth stay the same?
tcjones76
tcjones76
Tyngsboro, Ma
Tear down went OK this afternoon, I got it all apart before the rain set in.
old number 8
NOT Seattle
The pinion depth is set based on the diff housing carrier bearing centerline. You can replace as many carriers as you want without changing the pinion depth. The only way the depth could change and mess with the pinion setting would be to change the centerline of the carrier bearings (swapping bearing caps side to side or garbage between the bearing and housing)
Swap your carrier, but check the pinion for bearing loosness or roughness.
tcjones76
tcjones76
Tyngsboro, Ma
I told the guys in my local club that the locker is in, and now they are all saying, "now you're going break the axles!"
OK, so will the stock 30-spline shafts hold up to the new locker running 33's, Stock 3:50s and my tired 302-2V? Or should I expect snap, crackle and pop this weekend?
Viperwolf1
electron whisperer
It depends on how you use it. Don't put your tires in a bind where they can't turn and don't bounce the front over rocks with a heavy right foot and you'll be fine.
tcjones76
tcjones76
Tyngsboro, Ma
Thanks for the tips. Too bad the club motto seems to be "When in Doubt, Throttle Out!!!"
;D ;D
ken75ranger
Troy, NY
You should be ok. The mud on the rocks up here can save you. The lack of traction keeps things from getting too bound up. I'd take a close look at the ujoints though before giving it a pounding. Start looking for some spare used axles with bigger ujoints. Swap them when you can.
You won't need to "throttle out" near as much anymore.:cool:
tcjones76
tcjones76
Tyngsboro, Ma
Ken,
I just tested it on the rock pile in the back yard and it walked right up and over a 2-foot ledge, before there was always a lot of tire spinning, slipping, and cussing. This is going to be cool!! (I apologize for the over-the-top enthusiasm, but it's my first front locker;D ).
tcj
Viperwolf1
electron whisperer
One more thing, if you drive on snowy/icey roads in 4wd they don't work so well at turning corners. It will want to keep going straight even with the wheel at full lock. Try it in a controlled environment before you try it in traffic.
I have a track lock in the rear which is a handful on icey roads. In 2wd I can go anywhere but straight ahead. If I just lock the front hubs in helps to keep the bronco straight. If I put it in 4wd then straight ahead is all I have. I think I might upgrade to a selectable locker in front someday.
mr incredible
drive it like a white man , and you should be ok . get stupid , and expect the rice crispy noises to appear !!!
tcjones76
tcjones76
Tyngsboro, Ma
I love the extra traction, but the left u-joint snapped on Saturday and crackled the ears on the inner shaft. Pulled the axle and popped in a piece of hemlock to hold in the oil and 4X3'd the rest of the weekend. Time to upgrade the axles!!!
