Michael Mc
Im currently buying up parts to do a 4.56 gear change in my 76. I have the gears and a locker for the 9 inch rear and I have the gears for the Dana 44. I mostly use this truck for street and hunting on the weekends (nothing hardcore). So the locker in the rear will be all I need. I am looking at the 3.92 and up Yukon bare open carriers for the Dana 44. Will my stock spider gears and cross shaft fit in the 3.92 and up carrier? Also was not sure about the wear and tear that the stock spider gears go through and even if you need to reuse them. New spider gears are $110, master bearing install kit $100, and Yukon open carrier $83. Basically looking at a $200 expense for the carrier and spider gear set as opposed to the $400 to $1,200 lockers. Any suggestions or experience would be appreciated. Thanks
