dana 44 spindle shims.
bax
Old Member
I need to find a pair of tapered spindle shims for a disk / 5 bolt hole dana 44. Anyone got a supplier or a source for these. I had a set but can't find them now.
migs
Bronco graveyard has some, I just put a set of these on my bronco a couple months ago.
spindle shims
garberz
Bronco Influencer
Conejo Valley, Ca.
Good luck with your search. It's very difficult to find the 6" 5 hole shims, JBG has been out for quite a while. Some of the D60's are the same bolt pattern, I ordered some from Rock Auto. A few were correct, some were for the 6 hole GM 60's. ��
Mark
jwhit
moog still makes them i have part numbers at shop if you cant find shoot me pm
and i will get them also the same shim fits chevys and jeep
moog# k974-?? could be 3,4,5 depending on degrees
bax
bax
Old Member
Good number. Thanks. 12 bucks each, ordered. Moog K974-3
75MIKE
NE Washington
I hope you have better luck than me with the Moog number. As I had to send the 2 back to Amazon as they were the 4 3/4 diameter ones even though the description says 6 inch.
bax
bax
Old Member
for 12 bucks I can throw them in the street if they dont work
bax
bax
Old Member
I quess I will just hope I did not buy Frisbees ???
bax
bax
Old Member
Frisbees it is. The Moog number K974-3 is for a drum brake spindle. I need a K976-3. And I am not finding them.
Hozr
Rogue Valley, OR
Hey Bax, I meant to send this the other day. Not sure if this is what you are looking for. These came off a Dana44 Hi Steer knuckle/spindle. Only part number says "no. 5". They are 0.9mm at the thinnest and 2.7mm at the thickest. No idea what they are other than that.
bax
bax
Old Member
Hozr, Those are for a dana 44 with the drum brake spindles. The # 5 is how much taper is in the shim.
OK what I have learned in the past week looking for a pair of these is: No one has them. It is true that the graveyard has them on their site. However they are on forever backorder, they have zero of them.
The moog number used to be K976-3. That number is no longer good because they stopped making them. Doorman was making them under the part # 546-036 but Dorman sold them to a company called Ingalls Engineering. Ingalls part number is 56125 However they don't have any either and they make them, as I understand it. JBG turns out is getting / not getting the shims they sell from Ingalls. So full circle chasing my tail and never catching it. Clear as mud, I understand.
Anyone got a pair of shims I can buy?
Glass Pony
Sussex County Delaware
bax,
I have a single what I remember was a AC Delco 1/2 degree shim and 1 adjustable shim up to 1-1/2 degrees. I had them on a 1976 D-44.
bax
bax
Old Member
bax,
I would love to buy them from you. Was the d44 a disk brake?
bax
bax
Old Member
Thats what I need, one side is worse than the other so the 1/2 and the 1 1/2 may work. Would you like to sell them???
