Dana 60 swap
69earlybronco
Good afternoon everyone!
I need some insight on a new direction I am going with my 69 ford bronco.
I have a 79’ front ford Dana 60 king pin axle I want to throw under my bronco. From some research I have read these are kind of the best to throw under it since the driver side axle tube is longer for my extended radius arms I’ll be using and the housing “pumpkin” is away from the frame. After welding on the wedges and yes new steering and track bar. What else am I missing that needs to be done? Any advice would be helpful thank you.
79INA69
The pinion yoke on the D60 might be for a larger u joint. So either a conversion u joint or driveshaft modification may be necessary for fitment. Gearing in the axle obviously will need to match the rear axle as well. I have seen a spacer block used that will fill the gap between the radius arm caps. This is necessary if the axle tube is larger diameter. This might affect the lower coil bucket mounting. These are all easy fixes and should have parts on a shelf to remedy.
ntsqd
heratic car camper
Upper SoKA
Converting it to 5 lug, changing to an 8 lug rear axle, or going to run mismatched bolt patterns?
PNW
I put Snofighter '78-79 HP D60 in mine yrs ago and you really should check R&P housing clearances with not just the frame but with your trans & driveshaft.
Are you narrowing or going full width
What trans do you have now? Will you EVER change it?
The housing tube on the DS can cause interference issues with both of the above unless you do some fitting and run full cycle suspension checks to make sure nothing hits. My fitment had a bit more to it since I have a full 6" uptravel with only a 2 1/2" suspension lift but even with stock travel you should get out your tape measure because of the...
Trans and DS. If you ever decide to upgrade to a 4r70 or a 6r80 you need to set the housing in place to check for clearnaces before welding or deciding WMS.
69earlybronco
69earlybronco
I have a the James duff radius arms now and they say they work with a Dana 60.
69earlybronco
69earlybronco
I want to have it full width I only live a few hours from the rubicon. I have built axles now but I just want a worry free (with the family) for the most part I don’t beat itI have a 5.5 lift now and a np435 and doubler, eventually change to the ax15 and atlas.
A lot of info I have read is the snow fighter axle can pretty much be bolt up? What steering did you use and track bar? I am leaving the James duff radius arms and springs
PNW
Weld the C's on for the bushings after checking clearance to the pan, frame, trans & DS. Mine wouldn't have clearance at the trans or DS unless I cut the DS tube because I had to narrow mine. Can't run many PNW trails with full width axles. We have lots of trees. lol
If you're planning on going to an AX later make sure you weld the wedges on for the correct caster and pinion angle for the trans you decide you're going to be running. Caster stays the same but you pinion angle will be all screwed up pulling the doubler as it will be appr 6" shorter DS.
I currently run the late model 4x4x2 box with the correct guts to turn the correct direction with the pitman facing rear instead of forward (which I ran with the arm facing forward b4). It is up against the grill which is cut to allow it be be as far forward as possible. Everything under my rig is custom made- track bar, drag link, modified outer knuckles, etc. You're moving the spring buckets outward correct?
PNW
I forgot to add the only real weakness of those '78-9 Kingpin HP D60's are the outer "C"s. If you want the ultimate "we won't have to spend the night on the trail" configuration as possible, then go with the orange outers. :) I couldn't justify the cost when I did it. I did go RCV's which is well worth the expense unless you carry spares for each side like I used to for 30 yrs... really did - -and I sold a lot of them during those wheeling trips to others back in the D44 days.
I bought a custom formed weld on kit of pcs of 1/4" mild steel that you weld onto the knuckle to strengthen it. It was easy to weld it all up. When doing rocks with hydraulic rams you want to keep those knuckles in one pc.
Bad news is the market isn't there for them anymore and the guy I bought them from doesn't make that kit anymore. This was back in "budget days" when people tried to keep expenses down on projects, unlike now, it seems the average build is well over $100K. :(
1969
Reno, NV
https://irate4x4.com/threads/05-ford-super-duty-dana-60-axle-tech-info.4199/
05+ Super Duty Dana 60 vs the kingpin
PNW
Yup, those Super 60's are huge! Also, "mega-wide" for us Bronco guys!
1969
Reno, NV
72” WMS - WMS on the F250/350 version. I am sitting at 82” with my wheel and tire combo on my Bronco.
Everything on these axles is huge! Hard to beat getting one from the junkyard for ~$1000. You can run the 1550 axle shafts from the F450/550s in the F250/350 axle and they are a few hundred dollars.
69earlybronco
69earlybronco
From what I understand there is enough room on the axle tube because the center section is in further so the wedges are able to be welded on and keep the coil springs in the same spot? Or no?
jamesroney
Fremont, CA
Full float 60.
I have a narrowed 60 now so I’ll pull the center section guys out and my arb locker and install in the other one
So you are going to re-purpose your rear 60 ARB to put up front ...and THEN install a 14 bolt?
Just want to confirm that you are going 14 bolt in the back.
And the Sno-Fighter is the second best front 60 for a Bronco. It will have 3-1/8 tubes, and the duff arms will fit, but you will need to run c-cap spacers, or you will need to radius your wedges for the bigger tube. It actually ends up looking kinda puny since the tabs get really small. I stopped using the wedges and c-caps since the Jim Cole's arms already have bushings in them. So I just use his weld-on radius arm brackets. It cleans things up, and lets me run narrower. But I'm at 64 WMS. As long as you are full width, the pumpkin ends up where it ends up.
All dana 60 knuckles have longer tie rod to king pin leverage. This moves the tie rod forward. It also increases tie rod travel. So in order to get full turning radius, you need a longer pitman arm. These things work against each other, and the tie rod hits the pitman arm. So listen to @nvrstuk on this. I eventually ran a high steer arm for the drag link to get full travel.
You will like it when it's done. I like Dynatrac Pro Rock 60 for the ground clearance, but Sno-Fighter for the win!
ntsqd
heratic car camper
Upper SoKA
My friend Ruben put a D60/14bff under his 400ci powered FJ40. He's said many times that it was both the best thing that he ever did (quit breaking Birfields) and the worst thing that he ever did (massive increase in unsprung weight).
PNW
What James said above AND because of that distance between the king pin and tie rod which allows a tighter turning radius, you will not have room for a ram mount on your diff cover and if you want full travel of that tie rod then go with a manual pitman arm or go custom. I couldn't go TRO since I built for 6" up-travel and the tie rod would be 2 1/2" into the frame rails if I did go TRO so that was easy.
I built for 84" outside tire to tire to fit my trailer (yeah, that was my max #) so with outside of tire to outside of tire with 5" of offset it fit great. After going with the same size tire but with MUCH straighter sidewalls than the GY MTR's I had to make a trailer fender removeable. lol My wheel mounting surface was built at 68" and I have since had custom offset wheels built at 4 1/4". Everything fits great- nothing's easy... :)
Weight- my build thread has accurate weights
- my shaved 14 bolt weighs about 10# more than my fabricated 9" did.
- my HP D60 weighed about 50??#'s more than my D 44 did.
I thought all those FJ's were built out of cast iron!!! LOL
