It will be close. I checked to see if it would fit in mine by using a pc of alum that would have extended my Perf Auto adapter the equiv amt.
Yes, thanks for that question!A body lift will make a big difference. I have 2 1/2".
I used about 28" of 1/2" drive extensions with a socket to remove the top two bellhousing bolts which should pretty much prove you would be ok for clearance.
The 6r is taller but will clear your tunnel. In my tech article I addressed the twin stick clearance when bolted to the typical location on the flat part of the tunnel. The 6r is tall enough towards the back that things get tight.
It looks like that's what has went on here. I'm 99% sure the transfer case is the Dana 20 and I'd be willing to bet it's the original 3 speed too. No idea what the bellhousing came from. I'm guessing the original 170 didn't use the same bellhousing as a 5 bolt early Windsor, but I've never messed around with a 170 or 200. The plan is to pull the transmission and transfer case next.Just caught this thread & yeah you got a project going on here! Not sure what transfer case you're going with but I'm guessing you have the 6 cylinder(shorter) trans to transfer case adapter - that's one reason the engine would be pushed back into the firewall some? Then again who knows what they did to make things work. Just thought you might want to double check that trans to T-case situation.
Maybe I was overthinking things on the pedal ratio. Sounds like I'm good to go ahead and find a master cylinder then. The only drawback is now that I'm using a GM booster, I guess I'm committed to a GM spec master cylinder due to the difference in bolt spacing. I guess it's because I've always been into Fords and I've predominantly looked under the hoods of Fords, but man are GM master cylinders eyesores. I might have to pony the money up for a Wilwood.
I’m no brake guru, But I am currently working on a hydro boost conversion. Check out the last page of my build thread. Which is listed at the bottom of this post. The booster is Ford super duty, with Dodge diplomat master, at 1 1/8” bore. I’m running stock 76 Bronco front disc and rear drums. Will upgrade to rear discs later if I feel it needed.Looks like I've got the original Dana 20 which is great since I was planning on using it. I'm still planning on rebuilding the transfer case but I was really surprised at how smooth the input and output shafts feel when turned.
Now for a question for any brake gurus. I'm going to run a hydroboost brake booster and I'm working on acquiring parts. I've already got front disc parts from a 78-79 Bronco and I'll make the switch to discs on the rear, probably with a kit. My question is what size master cylinder bore do I need? I've read through some threads on here and the best that I can figure is maybe to go with a 1-1/16" or 1-1/8."
Also, will I need to do anything to change the brake pedal ratio to something closer to 4:1? I've never built a brake system from the ground up, so this is all pretty new to me. And if it makes any difference, I'll be going from 3 pedals down to only 2.
