Dash bar lights not working
Blue71
Took my heater switch out so in doing so I removed the dash bar lights that light up and tell what the heater controls, etc to make it easier shot at the switch.. I out the back in and they don't work now. Neither set and so I plugged them half way into the pigtail and ran a ground off of one lead and that set works. So I'm figuring there must be a ground wire that grounds all those dash bar lights. Anybody know where that wire is? Maybe I unhooked it and didn't realize it?
Thank,
Blue71
You may have simply damaged them during the fiddling too. As far as I know, there is no separate ground wire that goes anywhere to the case. Only the two wires at the connector.
So check both wires that connect to them. Do the same test for the second one you did for the first too. Take it out and see if that makes a difference.
If so, then either loose connector wires, loose connection inside (though kind of unlikely I think, based on how they're wired), or just the jiggling burned out a bulb or three.
Good luck.
CopperRanger
You can also check the lights themselves by hooking them up to a 9 volt battery
Viperwolf1
electron whisperer
Thank,
Blue71
Ground wire connects on the dash below the cigar lighter.
